Check engine light??
Hey everyone I'm new to this forum. I have some questions to see if anyone could lend some advice. We have a 2009 Honda fit sport. It runs good but then when you get to a 1/3rd of a tank of gas. The check engine light comes on. I ran the codes and the only ones it gives me is misfires on cylinder 3. I changed all the plugs, the coil and wire. It still keeps giving me that code. It doesn't lose any power or anything. I am at a complete stump. Any help will be greatly appreciated.
Have you picked the correct cylinder to work with? I often see posts where people mis-number their cylinder order.
Swap injector with one from a different cylinder, see if the misfire code moves and follows to the swapped position?
gfrobe
Jul 25, 2015 10:08 AM
