Trouble finding rims for Honda 2012 Base
Old May 26, 2017 | 01:13 AM
skier2.0's Avatar
Based on my VIN:
2012 Honda Fit Base Model
5 Door FIT (SAYAMA PLANT); KA 5AT
The number on the rim is:
J 15x5 1/2 JDOT (4 12 / 55 WK 18 MADE IN JAPAN)
So I know it is 15 inch diameter, 5 1/2 inches wide, 4 bolts
It started pouring so I haven't measured the distance between the bolts yet.
I believe the part number is 42700-TK6-A01 based on the Honda Parts Now web site.
I have gone to many sites--including Tire Rack--and even though I put in 2012 Honda Fit Base, none of the options come up with 5 1/2" diameter (except for very expensive fancy rims.)
Even when I look on sites based on diameter, width, etc., I cannot find 5 1/2" diameter rims.
Any suggestions where to get a rim for my Fit? I don't want to replace all 4 with a new size.
Attached Thumbnails Trouble finding rims for Honda 2012 Base-thumbnail_20170525_185811.jpg   Trouble finding rims for Honda 2012 Base-thumbnail_20170525_184043.jpg   Trouble finding rims for Honda 2012 Base-tire-wheel-disk-2836713.png
Old May 26, 2017 | 12:56 PM
iFitFITS's Avatar
Do you want to stay with a stock steel wheel? If so, Rockauto.com has it shipped for a little over $80.
If you want to go with something a bit more stylish i think the Civics from the early 2000's are a direct bolt-on.
Old May 26, 2017 | 02:26 PM
skier2.0's Avatar
Yes, I'm just looking for stock wheels as I only need to replace one bent rim.
Thanks for the info!
Old May 26, 2017 | 03:17 PM
shinjari's Avatar
You are looking for 15x5.5 +55 and the bolt pattern is 4x100. If you're simply trying to replace the steel wheel I'd call your local junk yard/auto wreckers. Or even check craigslist. Maybe someone with a base fit upgraded to an aftermarket wheel.
Old May 27, 2017 | 06:14 AM
Black3sr's Avatar
I have 4 for sale as just replaced with some nice ones. Too bad so far away.
ezdealz
Nov 12, 2012 05:57 PM
Snapcult
Aug 3, 2012 01:38 AM
connor55
Apr 15, 2012 01:26 AM
xmurked
Apr 6, 2012 10:08 PM
Scala
Feb 17, 2012 10:22 PM
