Should I go ahead and replace my clutch? Having occasional lurch issues...
Old Sep 3, 2017 | 12:45 AM
Turbocharga GE8's Avatar
Okay so my car is having some abnormal jerking when I up shift. I bought my fit used with about 89k miles on it, I've put about 10k on it and here are some things that I have have noticed or worked on.
So when I first got the car it was EXTREMELY jerky. Not smooth at all, I learned that the trans fill cap was leaking from not being tightened from the previous owner/carmax so I went ahead and replaced the trans fluid which helped with the smoothness of shifts, but overall did nothing for the jerk/lurch. So I kept troubleshooting, bought a bleed kit and bled the clutch fluid.. It was BROWN! But the funny thing is that in the fluid reservoir it looked brand new (this is a couple of months after I bought it) Could be CMC issue So the most recent thing I have done is change the slave cylinder, and reinforced my mounts...
I will say at this point the car feels pretty damn smooth, but it still jerks sometimes when I'm shifting occasionally, and I can promise that it's not driver error. I have tried shifting as slowly and smoothly as possible and it still happens... I'm thinking it's either the CMC/delay valve from being clogged with the nasty fluid that was probably in there since the car came off the assembly.. I already have a clutch kit, but I don't want to replace it if it doesn't need it.. It has slipped on hills before, but that stopped when I changed the slave (maybe the second bleed fixed that?)
Anyone had a similar experience? I'm planning to start using my fit for ride sharing and I'm afraid someone is gonna snap on me (or snap their neck) for not shifting smoothly lol!
jaedmaloy
Mar 18, 2018 04:55 PM
samcl9
Nov 25, 2016 09:51 AM
BrianFantana
Jun 22, 2013 09:51 AM
da9r00d
Jun 8, 2011 11:20 AM
apexanimal
Jun 15, 2010 11:39 PM
