'09 Sport crankshaft position sensor
Old Sep 11, 2017 | 08:48 PM
Maw230's Avatar
Anyone know where to find this part? And what it takes to replace it? My wife's fit is dead 2 states away, and we think this may be the culprit. Thinking a recent oil leak toasted it.
Either way, any help is greatly appreciated!!!!
Old Sep 11, 2017 | 11:10 PM
CEPAfit's Avatar
not sure if this diagram helps you, but it would be #5 on the diagram listed. Honda Fit Sensor assembly, crank. Cylinder, chain, case - 37500-RAA-A01 | Sons Honda, McDonough GA
Old Sep 12, 2017 | 11:37 AM
Maw230's Avatar
Yes, very helpful. Looks like I would need to remove the timing cover to access this part? Does anyone know if the crank pulley needs to be removed?
Old Sep 12, 2017 | 05:02 PM
dwtaylorpdx's Avatar
On my GD the crank sensor is removed from the rear side of the motor, 1 bolt 1 connector I'd estimate 10 minutes tops.. ON mine its in the open, you don't need to touch anything else.
You might even be able to swap it by reaching from above on the passenger side. if your coordinated..
3/8 ratchet and a deep well socket set.. If I recall it was a 13mm..
If you do it from below the aero tray has to come off,, or at least the passenger side needs to be taken loose at the upper part the sensor is kinda visible through the wheel well..
Good luck.
Old Sep 12, 2017 | 07:24 PM
Maw230's Avatar
Man, if that's the case for the GE then shit. I already had to send it to a mechanic cause I couldn't find documentation ANYWHERE ONLINE of where it is on the GE or that motor at all. Not much I can do two states away. But here I sit hoping I found an honest and knowledgeable mechanic..
Old Jul 28, 2024 | 01:41 PM
Honda2009Mt's Avatar
Crankshaft sensor
I took some videos and I can’t seem to find this sensor neither the cam shaft sensor. I have a manual transmission and I looked on the drivers side near the crank pulley and nothing.
then I looked by the intake manifold and nothing.
Any closer pics?
Good luck.
Geefit
Jul 24, 2025 04:45 PM
Mapone
Feb 27, 2014 09:56 AM
devmail
Jan 18, 2014 10:37 PM
npreuninger
Mar 13, 2013 11:41 AM
contagiouss_blue
May 4, 2005 04:44 PM
