EPS Warning Light ON. Need Help!
Old Nov 30, 2017 | 09:04 PM
nathanmanips's Avatar
Hey Guys,
Currently I am having problem with my Honda Jazz 2010. EPS (electronic power steering) light comes on and steering becomes heavy.
When I check using the scanner, it says "Torque sensor coil malfunction" fault code 51-5. So I reset the EPS and the EPS warning light
was gone and all working fine. But while driving, I bump a little on hallow road, the EPS light again comes on and the steering becomes heavy.
It happens Twice, so I think there is something loose? IDK.
I need your experience regarding this guys before I bring it to mechanic. Because repair here in the Philippines is very expensive, so I wanna
make sure what will be needed for the repair or parts to be replace.
Thanks you for your HELP
elkenhausen
Jan 23, 2022 05:22 AM
nathanmanips
Dec 11, 2017 03:56 AM
mzpinetree
Oct 19, 2011 03:56 PM
jdzz
Feb 28, 2011 12:34 PM
Solscud007
Aug 4, 2009 03:14 PM
