Electrical Diagram Trunk, Locks, - 2011 Fit Sport
Old Dec 7, 2017 | 02:39 PM
JLM2.0's Avatar
Can anyone please send me a wiring diagram for a 2011 Fit Sport - Suzuka Plant for:
1) All power door locks including tailgate.
2) The sensor circuit that shows when a door is open, also with tailgate.
Problem: Upon replacing a bad tailgate actuator lock, the new lock now works but the system thinks the tailgate is always shut. I may have received a bad part where the switch in the new actuator is always open. Just attempting to verify everything before going down that road.
Much appreciated.
Update: 12/11/2017
Tailgate door switch circuit had bad connection at pigtail connector to harness. When connected correctly, it would get an intermittent bad connection when pushed / pulled. The quick tell was that the trunk light would flash on / off when touching the connector - Lucky find because all the wires looked good from outside.
The fix was to just bend the prongs on both side of connector to make a tighter fit = solved.
dongetti
Jan 22, 2024 10:05 AM
djk2
May 18, 2018 02:04 PM
LVFit
Jul 7, 2016 08:56 PM
Stupendous
Apr 28, 2015 04:56 PM
doodedge
Feb 9, 2014 09:55 PM
