Front end noise help
Old Jan 17, 2018 | 03:48 PM
rutterhups's Avatar
I have noticed a noise coming from the front end (I believe the passenger side) for about a week. It is intermittent, occurring only when turning to the right with a fair amount of wheel turn required for it to happen (such as pulling out from a parking lot 90 degrees). Typically happens in the 20s-30s MPH range, never hear it on the freeway. Only occurs turning right, never while going straight or to the left, and when it occurs it is a constant scraping type sound, with no shaking or vibration.
In the video (sorry for potato quality) you can hear the scrape/screech intermittently starting after 1:00.
<iframe width="560" height="315" src="https://www.youtube.com/embed/yDZyhVuVNkE" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
At first I thought wheel bearing but it does not seem to be worse with higher speeds and the strong association with turning makes me wonder if it could be a warped part of a brake rotor that is making contact at certain degrees of wheel turn only?
I will put the car up on jacks and get the wheel off tonight.
Any thoughts?
Old Jan 17, 2018 | 04:56 PM
rutterhups's Avatar
Details: This is a 2013 Base with 78,000 miles, no prior brake or suspension work has been undertaken. New winter tires installed 11/2017.
Old Jan 18, 2018 | 11:55 AM
Mister Coffee's Avatar
Not sure I heard it, but from your written description I would look at brakes (pads and rotors) first.
You'll know more when you lift the car and spin the wheel by hand and listen.
Good luck.
Old Jan 24, 2018 | 08:00 AM
spike55_bmw's Avatar
I'm sure that the lug nuts are tight.
Have you changed the front brake pads recently or should they be changed? At this mileage, the caliper piston could be hanging up, wearing the pads on one side faster than the other and the "alert" metal strip might be intermittently touching the brake rotor.
I just recently saw this on our CIVIC with 110K miles.
fujisawa
Jan 7, 2025 09:23 PM
Ssainsbu@yahoo.com
May 17, 2016 10:29 PM
MagicGuitar
Oct 13, 2015 05:14 PM
xcsp800
Feb 7, 2014 01:26 AM
aZnCdn
Mar 27, 2010 07:53 PM
