Airbag Light
Old Oct 16, 2018 | 01:23 PM
tyler968's Avatar
Airbag Light
Hey, I have a 2009 GE8, I swapped seats from a 2012 GE8, now I'm getting airbag light. Just wondering how I can get this fixed?
Old Oct 16, 2018 | 01:33 PM
evilchargerfan's Avatar
please advise of the following .... during the seat swap:
A = my battery was disconnected (negative terminal)
B = my battery was not touched during the entire process
Old Oct 16, 2018 | 01:57 PM
tyler968's Avatar
That's correct my battery was not touched and it was disconnected.
Old Oct 16, 2018 | 03:05 PM
so just so I understand.... it was NOT TOUCHED .... but yet .... it was somehow .... DISCONNECTED?
Old Oct 18, 2018 | 12:27 PM
tyler968's Avatar
So just to make sure we're on the same page here's literally everything I did...
1)disconnected negative terminal
2)disconnected 2009 seat and removed 2009 seat
3)connected 2012 seats and bolted up 2013 seat
4)connected negative terminal
Old Oct 19, 2018 | 06:32 AM
Marc Papa's Avatar
I can tell you this, along with my 2010 Fit, I have an 05 Acura TL with my airbag light on. I had the code scanned and it comes up with 61-10 Permanent DTC Open in the drivers seat belt buckle switch. There's a sensor in the actual buckle that went bad on my Acura which will trigger off the airbag light. Apparently it is still covered under Acura's warranty because it's part of the restraint system, although I haven't had the time to bring it in to be fixed, or had the time to have my drivers side airbag replaced on my Fit. Not sure if that's what's causing your airbag light to come on, but it may be.
Old Oct 19, 2018 | 01:24 PM
to test out marc's theory .... repeat your steps, but restore the original seats
report back with your findings
Old Oct 19, 2018 | 02:44 PM
tyler968's Avatar
Will do! I'll contact the person I swapped seats with, as he's getting the exact same error.
Old Oct 19, 2018 | 02:53 PM
tyler968's Avatar
I just did some checking, because we did swap the buckles, could it be the OPDS? If so, is OPDS something that can be reset?
Old Oct 21, 2018 | 02:36 PM
SiXiam's Avatar
I can't speak for the Fit, but with my old 2001 Kia Rio I had to unplug a wire under the dash to install something and I got a continuous air bag light (until the light burned out). I plugged it back in right away, but it didn't care.
The airbags obviously need some type of computer reset I couldn't do. On the bright side the airbags deployed properly when the car was totaled in a crash a year or so later.
Old Oct 22, 2018 | 12:03 PM
tyler968's Avatar
I'm not really up for taking that kind of chance lol
Old Oct 22, 2018 | 06:47 PM
SiXiam's Avatar
Then you will have to go to the dealer to get it checked. It sucks, but the price of peace of mind
Old Jun 25, 2022 | 04:44 AM
Ish G's Avatar
Air bag light on after seat swop
Hey Tyler,
Just checking you managed to get your SRS light resolved. I changed seats between a 2009 and 2012 model and have the same issue.
It would be appreciated if you can shed some advice on what you ha e done to resolve.
Regards
Ismail
Old Jun 25, 2022 | 10:47 AM
tyler968's Avatar
Unfortunately I haven’t I’ve been waiting for help on that for a while but haven’t made progress. I would’ve though swapping early GE8 to late GE8
Old Jun 25, 2022 | 10:14 PM
howarejew's Avatar
ODS module needs to be reinitialized (the weight sensor in the passenger seat)
Old Mar 5, 2025 | 06:46 AM
tjlong1981's Avatar
I remember watching a video of someone swapping out Civic seats into the Fit and the connectors are the same, but two of the pins are swapped. It could the pins swapped between the different years.
upaddZ
Jul 1, 2016 11:37 PM
AshleyyOnPoint
Apr 14, 2014 09:45 PM
Marvino
Feb 8, 2011 07:50 PM
Fat Ping Cat
Jan 2, 2009 03:28 PM
Darkstars
Mar 11, 2008 10:16 AM
