Cracked frame--Anyone else seen this??
Old Oct 19, 2018 | 11:59 AM
crabs's Avatar
Hi, newbie here. I was filling my tires yesterday and found cracks in the frame, looks very serious. Is this a common/known issue? Looked around here and couldn't find any other mention of these types of cracks.
I have a 2010 Base Fit, just passed 130,000 miles, of course the warranty just expired at 120,000.
Any advice?? Worried my car is now totaled...
Driver side rear wheel
Old Nov 2, 2018 | 10:42 AM
Davidm5's Avatar
Looks like you hit something based on the scrapes and cracks above the other crack.
Old Nov 2, 2018 | 03:42 PM
Black3sr's Avatar
Is this under rear bumper cover? If so maybe backed into something and damaged without hurting outside of cover. Does not appear to be in suspension so not to worry.
A pic or two from further away would help us locate exactly where this is.
Old Nov 2, 2018 | 04:00 PM
Flashesbuck's Avatar
I think im about to make your day...
Take another look, it looks like tar to me from the road. Find a strong solvent and try to wipe it off.
Old Nov 3, 2018 | 07:09 AM
Goobers's Avatar
It's in front of the rear wheel. There's a piece of plastic called the "strake" and it's only installed at the bottom in front of the rear wheel.
The bolt next to the strake is the bolt that holds the rear torsion bar.
As for the "crack"... it could be tar like flashesbuck said, it could be a crack in the frame, but then again, there's a "protective" coating on the metal, so the crack could just be the coating itself too. Would need someone a bit more professional to get an actual hands on look... not just random forum people looking at a picture.
Old Nov 3, 2018 | 12:05 PM
GAFIT's Avatar
Hard to tell in a picture, but my guess is that it's the coating that is cracking.
Old Nov 3, 2018 | 01:49 PM
fujisawa's Avatar
If it were cracked frame, wouldn't there be rust?
Old Nov 4, 2018 | 06:57 AM
spike55_bmw's Avatar
As you can see my 2011 Sport driver's side and the leading edge of the rear wheel well has a lot of similarities with that "swoosh" of sealant in the same area as crabs'. I have to assume that crabs knows the difference between road tar slung up on to the wheel well versus a crack in the metal but have to agree with other posters that some look "tar like".
If in fact it is dented in and cracked it may have happened from a side impact. It wouldn't happen backing into anything. I'd start looking around for other deformities under the car. Maybe it had been repaired. Check the 4-wheel alignment too (is that tire wearing more than the others?).
Old Feb 21, 2019 | 07:19 PM
wwjd's Avatar
^^^ This ^^^
Well?
Old Feb 22, 2019 | 04:00 PM
evilchargerfan's Avatar
Originally Posted by wwjd
^^^ This ^^^
Well?
+1
waiting on a damn reply from the op =\
Old Feb 22, 2019 | 06:27 PM
upallnight's Avatar
Most modern cars are built on a unibody with subframes. That doesn't appear to be a subframe, so I would say that you don't have a crack frame.
Old Feb 22, 2019 | 08:01 PM
steve37's Avatar
Crabs first and only post...lol.
saxoftenest
Dec 20, 2013 12:49 PM
I_Use_Maps_(as_in_paper)
Sep 28, 2012 03:08 PM
trandi22
Feb 4, 2012 01:52 AM
The111
Aug 11, 2010 05:13 PM
ThEvil0nE
Jun 28, 2010 07:09 PM
