Fixed oil pan leak at 92k , pulled the oil pan and resealed and replaced the gasket and o ring. , it was leaking on the passanger side just below the crank seal, I first thought it was the crank seal until I went to replace it , pulled the d@#$% Honda crank bolt and pulley and found it was leaking between the block and pan put it all back together and ordered the pan seal kit, Not too bad a job just a lot of steps , about 3 hours on the lift.
Love having access to a lift. This end is only sealed with Honda bond.
