Humming noise coming from front after bearing/hub change
Old Oct 28, 2018 | 10:26 PM
Gobstopp's Avatar
i replaced my front hubs and bearings on my fit. Car is a 09 with 135k. I pulled the knuckles myself and had a Honda dealer press the old hub/bearing out and press oem hub/bearing back in.
After i I reinstalled the knuckle, I did not get an alignment. I was planning on it, but I feel like I need to replace my axles and front control arms and steering linkage, and if I was to do that, the car would definitely need another alignment.
ive been driving the car for weeks, my commute is very short, and I since the install I never had any noise or issues at all. Done all sorts of driving, different speeds, different turn directions, never any noise.
A few days ago I drove 40 miles to my friends house down back country roads, no noise, no issues. I then got to a 2 mile section of brand new freshly paved road, so new there wasn’t even lines painted. On this new road, my front end started to hum, going straight, turning left or right didn’t seem to change anything. It’s perplexing, I turned around and drove back and forth down the section and the car would hum, but I can’t get the car to make the noise on any other road.
Im not sure what’s the issue, could it be the new bearings? If it is, why won’t it make noise on any other road? Is it due to the fact that I didn’t get an alignment? I can tell the car needs one, but I didn’t think it would be detrimental to drive in the mean time.
The axles have some play, but they don’t click in turns or anything, but the new hubs and bearings feel so smooth when driving, that it made me realize how worn the rest of the front end suspension is
Old Oct 29, 2018 | 12:44 AM
GE82010's Avatar
Could be the road
Old Oct 30, 2018 | 02:51 AM
GolNat's Avatar
Sounds like the road to me.
Old Nov 1, 2018 | 08:50 PM
upallnight's Avatar
Concrete highway or Asphalt paving? If it was a concrete highway most likely it's the groves they made in the concrete to channel water that is causing the humming noise you hear.
Aimee Nord
Mar 12, 2021 04:35 AM
Sparky1967
Oct 6, 2016 12:38 PM
MTLian
Apr 20, 2015 03:51 PM
rickow1
Aug 6, 2013 01:01 PM
Piscator
Mar 8, 2013 08:40 PM
