2013 Honda Fit radiator fan replacement
Old Jan 16, 2019 | 12:21 PM
Fit2000's Avatar
A friend of mine got a radiator fan replaced and it's super super super loud. It's ridiculously loud. In any case, I want to replace it. I want to help her out but I'm not totally familiar with the Fit.
First things first...
A) if sitting looking into the engine compartment from the outside front (facing looking towards the read of the car), the fan on the right is the cooling system fan? (the one on the left is the condenser fan?)
B) Where can I get the OEM fan? Part number?
C) How do you remove the assembly and replace the fan + motor? I assume it's just one assembly that includes the motor, fan, fan housing?
D) Are there any shop manual screenshots or PDF how-to?
Thanks kindly.
Old Jan 16, 2019 | 01:42 PM
evilchargerfan's Avatar
B) behold, the magic of rockauto.com
C) and D) , I believe there are a few threads out there, where members have shared downloadable links, to manuals which should contain instructions on assembly/disassembly
GL, search is your friend.
Old Jan 16, 2019 | 07:51 PM
JerrySFL's Avatar
Easy to change, just a few 10mm bolts and clips to pull.
Old Jan 17, 2019 | 01:16 AM
Fit2000's Avatar
Excellent, and I was able to find parts here: https://www.hondapartsonline.net/aut...er=19015rb0004
Old Jan 19, 2019 | 12:43 AM
Fit2000's Avatar
Excellent.
Thank you.
Gerald Grimaldo Abellon
Jul 30, 2019 11:49 AM
boltaction
Jul 11, 2018 10:52 AM
averona
May 26, 2016 07:42 PM
nosliwmit
Nov 29, 2013 03:59 PM
Thor28
May 22, 2007 11:17 AM
