Front Passenger Side Motor Mount Replacement
Old Apr 22, 2020 | 07:30 PM
triton.'s Avatar
Hi All,
I need to replace Front Passenger Side Motor Mount. OEM Part Number 50822-TK6-901. This is for a 2nd Gen Honda Fit AT.
Overall procedure (Please correct if my steps are wrong)
1. Jack up engine slightly with 2x4 or 1x6 block of wood under oil pan.
2. Disconnect Motor Mount Bracket
3. Disconnect Motor Mount and replace
4. Lower engine back down.
Questions I have,
Does anyone have torque settings for the bolts (both for the motor mount and the Bracket)
Has anyone tried using the Generic version, looks like they go for about $30-40 for one mount or about $80 for all three mounts). Is there a specific aftermarket version that people are seeing more success with?
Should I not bother with aftermarket and just get the OEM version (about $130 right now).
Thanks in advance.
Few Questions
Old Apr 23, 2020 | 01:28 AM
GolNat's Avatar
I'd get the OEM ones.
People have had issues with cheap aftermarket ones on Civic's.
Yeah it's 4x the cost but you are saving money by DIYing so $130 to do what the dealer would be doing is good IMO.
GinoLicious
Jul 13, 2022 02:35 AM
ChuckDustin
May 15, 2019 01:33 AM
fit2bking
Jan 27, 2016 01:10 AM
MTLian
Aug 15, 2014 04:06 AM
apexanimal
Jan 13, 2012 10:00 PM
