Heater/AC blower fan only works on high
I am having trouble figuring this one out. I find info about other vehicles but nothing on 09 Fit.
The blower will not work on any setting but the highest. Heat and AC both still work but I have to set the fan to full blast. The AC compressor still comes on with the fan setting in positions other than high.
Any ideas what is going on here?
Something's going on--I have read it somewhere...
Check out this thread...
https://www.fitfreak.net/forums/2nd-...l-1-3-out.html
The reason is likely the motor control module failure due to excessive heat (older Honda's had them partially installed in the air intake plenum to cool the thermistor). Excessive heat is caused by not replacing the cabin air filter often enough resulting in lower air flowrates that leads to the thermistor overheating - thus failing.
seanpatrickk
Aug 10, 2015 07:32 PM
DGFitness
Feb 20, 2011 10:40 AM
