Transmission Cooler Return Line?
Old Apr 30, 2010 | 08:58 PM
jadr09fit's Avatar
Which line coming from the transmission cooler in the radiator is the return line? Is it the short line on the left, or the long line on the right (as you're looking down on the cooler lines)? I ordered a Magnefine inline transmission filter, and want to get it into the return line. Thanks!
Old May 1, 2010 | 04:03 PM
koolkevin1107's Avatar
Try this. turn on ur car for about 5 min, then turn it off. Go and touch both tranny cooler lines (don't worry it won't be too hot) and the one that is cooler is the return line. IIRC it's the one on the left when ur looking down
Old May 1, 2010 | 07:39 PM
jadr09fit's Avatar
I tried that, and I guess my fingers aren't too sensitive. I do recall the left line being a little cooler than the right line. Thanks!
Old May 1, 2010 | 10:24 PM
jadr09fit's Avatar
I ended up putting it in the longer feed line since it was much easier to work with, and will dissipate heat better there.
Old May 1, 2010 | 10:38 PM
Perrenoud Fit's Avatar
Arrow #5 is the trans filter
Old May 2, 2010 | 10:02 AM
jadr09fit's Avatar
This is over and above the regular filter. What can I say, I like my ATF like my drinking water, filtered!
And thanks for posting that picture! I can see the big long line is the feed line coming from the differential or torque converter, and the smaller line is the return line going to the sump.
Old May 16, 2010 | 10:10 AM
jadr09fit's Avatar
Update: So far so good. Looks like the giant, long line is the feed line, and the short line is the return line.
okey0
Dec 31, 2018 09:36 PM
aboutblank
May 10, 2018 09:19 PM
Zardiw
Apr 5, 2017 08:09 AM
07fitsport
Jun 24, 2008 04:30 PM
LuxuryFit
27
Dec 18, 2007 07:32 PM
