HELP Disable Daytime Running Lights???
Old May 2, 2012 | 08:01 PM
quentinbeware's Avatar
Question HELP Disable Daytime Running Lights???
Hi people I own a 2009 Red Fit and I just installed a pair of headlights to make it cooler.
Unfortunately I wasnt able to disable the DRL and the headlights keep turning on every time and release my E-brake.
I heard pulling off the #15 fuse would disable the DRL
But I dont know how and which one to pull ><
Old May 2, 2012 | 09:04 PM
Goobers's Avatar
When you've got your head down there looking at the fuse panel... look to the side, next to the door.
Old May 2, 2012 | 09:34 PM
annunC8's Avatar
Not trying to sound rude, but, try reading your manual. One of the first things I did was disable my DRL by removing the fuse. (a very small one, btw!)
How did I know which fuse to remove? !SURPRISE! I read my manual... specifically the section that shows you exactly which fuse does what... including which fuse is for the DRL. !SURPRISE!
It's been awhile, so I don't remember which fuse it was. I'm not making a trip to my car to find out again either... you can do the same thing for yourself, feel like you accomplished something, and solve your problem immediately.
Good luck with your fuse-finding venture!
Old May 2, 2012 | 10:51 PM
mkane's Avatar
^^^^^^^^ wise guy. #15 will do it.
Old May 3, 2012 | 12:55 AM
Goobers's Avatar
The OP's problem is, he doesn't know which one is #15.
Hence my comment about looking to the side. There's a fuse layout printed onto the panel.
Old May 3, 2012 | 04:54 AM
Thanks people, problem solved!
Old May 3, 2012 | 10:15 AM
mkane's Avatar
And that label's a bear to read, peels off nice.
Old Jul 28, 2012 | 09:36 PM
david223's Avatar
This may sound crazy but why would you want to disable daytime running lights? They are for safety.
Old Jul 28, 2012 | 09:52 PM
thefit09's Avatar
For future reference, it's the 2nd column, 5th up from the bottom. The 7.5 amp... IIRC.
Old Jul 28, 2012 | 09:53 PM
MeTaLoFeArTh's Avatar
You may want to leave the car running but not necessarily have headlights on.
When I leave my girlfriend in the car for a few moments and leave the car on so she can have heat or a/c, I don't like that the lights stay on and announce that the car is running. Especially since she doesn't have a power door lock switch on her side to lock the doors behind me.
Not making it easy for the passenger to lock or unlock the doors is a poor design imo. And I need to get down there and pull that fuse.
Old Jul 29, 2012 | 10:11 AM
malraux's Avatar
There's a cave in town that does this drive through Xmas lights display. Drl is kinda a jerk thing there.
Old Jul 29, 2012 | 06:51 PM
Colincarguy's Avatar
The Fuse your looking for is a dark Red one, and if i remember correctly stands alone. so #15, dark Red, stands alone, theres a photo floating around here somewhere that shows exactly which one.
Old May 28, 2015 | 12:35 PM
jfcl's Avatar
DRLs are of marginal use
The main problem with DRLs is the implementation. No DRL implementation illuminates the tail lights and many DRLs (not the Fit) use lights that are closer together than headlights.
For these reasons, DRLs never qualify for state laws requiring headlights, such as when it is raining or other hazardous conditions. Headlights and tail lights are required by law. Under poor visibility conditions, closely-spaced DRLs can make a vehicle appear farther away than it really is.
DRLs do provide a marginal safety advantage if you don't use your headlights. I use my headlights all the time so they are just a nuisance to me.
Old May 28, 2015 | 11:58 PM
connor55's Avatar
Drls are required by law up here. Probably because we are more likely to run into foggy or white out conditions and our cars need to be visible on big open highways.
hnickm
Nov 28, 2015 08:29 PM
j5ive
Canada Fit Forums & Clubs
18
Sep 16, 2014 01:52 PM
alanchan
Jun 1, 2012 12:05 AM
Marsbars
Sep 25, 2009 06:47 PM
fit2bcrazed
Nov 30, 2007 03:43 PM
