A/C Problem (Fit Sport 2009)
Old Jul 15, 2012 | 01:05 PM
Underwoo's Avatar
Have an A/C issue:
Cold A/C air will stop after driving two hours or longer.
The AC continues to work on the long trip, but the air isn’t cold.
After the car has been sitting for a while, it starts to work just fine again.
Did anyone experienced similar issues and was able to solve it?
Please Advise
Thx
Old Jul 15, 2012 | 01:25 PM
AC7880's Avatar
Lots of threads on here with similar AC issues. Search and read the old threads for the best information.
My guess: low freon level in the system and icing. Have the freon level checked by a pro with proper equipment (not the store bought gauge - not accurate at all).
Old May 20, 2013 | 01:30 PM
donovaj's Avatar
air conditioner doesn't work when you need it most
I just went on a car trip to Florida. During the trip my car went past 60,000 miles. I'm now at 60,380. So I guess I'm out of warranty. The air doesn't work after a few hours. I read online on a different forum there is some sort of heat exchanger under the car that can easily be hit by road debris and the coils are now all mashed together which is my problem. The fins on the coil must be awfully thin and thus a design defect. I've never done anything but Atlanta highways to and from work and the I-75 to and from Florida in the car. Does anyone know how to get Honda to fix this other than a class action lawsuit for defective design? It isn't something you would realize was an issue until you go on a long trip as the car works just fine around town.
Old May 20, 2013 | 01:51 PM
Eugene.Atget's Avatar
Some have had this covered by their insurance, so you might look into that. Once it's replaced, look into protecting the new condenser with gutter guard or something similar. There are several threads on how to do so.
Old May 20, 2013 | 04:47 PM
Steve244's Avatar
This is due to low refrigerant, a defective evaporator thermistor, or a defective expansion valve. Either condition results in the evaporator coil (a heat exchanger inside the cabin) freezing up. Turning off the A/C for a while allows the ice to melt and the A/C to function again. Either of these three conditions can cause the A/C to "work harder" and freeze up. More than likely just low refrigerant. Have it serviced by Honda or some other certified A/C tech.
All cars share this design (some sort of [A/C] heat exchanger in the front of the radiator). Most cars have an open lower grill that would allow rocks or other road debris thrown up to hit this. Very few have grill that would block these. Of the 4 cars in my driveway: 95 Miata, 97 Camry, 03 Accord, 09 Fit, all have open lower grills.
If the condenser coils in front of the radiator had been holed by a rock, it would not cool at all; all the refrigerant would have leaked out in seconds.
I'm now at 60,380. I've never done anything but Atlanta highways to and from work and the I-75 to and from Florida in the car. Does anyone know how to get Honda to fix this other than a class action lawsuit for defective design?
The warranty is 36K miles or 36 months. I don't think you have grounds for a lawsuit. You could ask the service manager for a "good will" repair, and if he is unable to provide this, call NA Honda Customer service. I don't think either will be forthcoming as there is no design fault and the car is far out of warranty.
If it was damaged by road debris, this is not a warranty fix anyway; it would be up to your car insurance comprehensive policy.
from the owner's manual:
Originally Posted by owners manual page 332
Honda dealership personnel are
trained professionals. They should
be able to answer all your questions.
If you encounter a problem that your
dealership does not solve to your
satisfaction, please discuss it with the
dealership's management. The
service manager or general manager
can help. Almost all problems are
solved in this way.
If you are dissatisfied with the
decision made by the dealership's
management, contact Honda
Customer Service.
U.S. Owners:
American Honda Motor Co., Inc.
Automobile Customer Service
Mail Stop 500-2N-7A
1919 Torrance Boulevard
Torrance, California 90501-2746
Tel: (800) 999-1009
Again, that it works at all is an indication of the problems listed above. It probably just needs topping off with refrigerant.
I feel like a bit of a Honda apologist; but really, this is common to all cars. The repair, if just adding refrigerant is less than a couple hundred dollars.
Old May 21, 2013 | 12:53 AM
loudbang's Avatar
The problem is USDM Fits have a much larger opening in the front below the grille. The rest of the world has a smaller opening and no reports of condensers being damaged by flying debris.
Like others have mentioned there are several threads about protecting the condenser using cheap hardware store type things.
Old May 21, 2013 | 10:45 AM
Steve244's Avatar
mmmm visit any parking lot and make a visual survey. I think you'll find that there isn't a big difference between the Fit's lower grill opening and other makes. Some cars have smaller grill openings, but I think this is more aesthetics than protection (and that goes for JDM Fits). And the rest of the world doesn't have a significant difference in condenser damage that I'm aware of. Perhaps the rest of the world has less road debris. I think I've only heard of one person here having to replace the condenser on their Fit due to damage. There are several that have had freezing issues unrelated to condenser damage, and quite a few complaining about inadequate cooling (normal operation).
There are an inordinate number of people here adding gutter-guard to their grills I've noticed. Might be peer pressure. The Fit's condenser is not painted black, so people notice it more. That might be the main difference.
ahh, a poll I missed.
OK 9 out of 143: 6% of respondents (I didn't respond). That's significant, but I don't know if it's more than any other car.
Old May 21, 2013 | 11:15 AM
cjecpa's Avatar
I did the DIY on the lower grille protection located in the forum. The one DIY I cannot find or at least I think there is one, is the A/C insulation of the hoses.
Old May 21, 2013 | 11:23 AM
Steve244's Avatar
yeah, somebody put neoprene pipe insulation around their low pressure (return) A/C hoses. Really some obsessive folks here...
Old May 21, 2013 | 11:27 AM
Steve244's Avatar
^^ really
This appears to be a bigger problem
No report of having to replace the condenser either...
Old Jun 7, 2013 | 11:46 PM
Ando's Avatar
I had the same problem as the OP last year on vacation. I thought it needed refrigerant, so I made an appointment with Meineke. They said it didn't need to be charged, but they had found some sort of TSB about ALL Hondas with A/C. This TSB said that on long trips at highway speeds, the A/C line freezes. Turning it off for awhile lets it thaw and it works again. The "fix" is to do a complete A/C charge (even though it technically doesn't need it)--that re-creates a vacuum and doesn't allow water vapor in (which is what freezes). Since it was the end of summer when I found this out, I put off the A/C charge. I just had it done last week, because I'm going on a road trip next week. Hopefully, that fixed it--and it cost only $95 at Meineke.
Old Jun 9, 2013 | 09:15 AM
Steve244's Avatar
I'd be interested in seeing the TSB. I think Meineke made that bit up. Evacuating and recharging can remedy moisture and incorrect refrigerant levels which is probably why they chose to do this (it's also the easiest).
There's a lengthy troubleshooting procedure. Excessive moisture in the system is just one possibility. A faulty temperature sensor is another likely cause.
Old Jul 8, 2014 | 03:22 PM
medbill's Avatar
Just found this thread on a search as the AC in my 2009 FIT can't seem to handle the high 80's low 90's heat we are experiencing. The car is new to me with less than 30k miles with extended Honda warranty. I am bringing it into the shop on Friday. It also lost almost all cooling on the way home yesterday while driving about an hour and a half on the hwy and it was barely blowing out cold. The car sat for about 20-30 minutes went back in it and it blew cold again. Never really as cold as it should be for a car's ac but cold all the same. Hope its just a recharge and I will search to see if I can find that TSB! Will post what happens for the next guy.
Old Jul 8, 2014 | 05:57 PM
Bama3Dr's Avatar
That all sounds like the evaporator coil freezing up because of low refrigerant to me. I'm having the same problem with my 2012....planning to take it to the dealership and let them look at it. I hope they don't charge me an arm and a leg because I'm well out of warranty.
-Dustin
Old Aug 20, 2014 | 02:37 AM
honda599's Avatar
Just had similar problem ac was working fine then blew only warm air, after awhile it started working okay. Traced problem to intermittent ac relay malfunction located in engine compartment. CRVs having same issue and is same part number for relay. Wears out from ac cycling so much. Replaced relay problem solved. I also bought gutter guard to provide extra protection for rocks going through grill to damage condenser...seems to work good.
Old Aug 20, 2014 | 09:47 AM
"FIT 2 B Tied"'s Avatar
I had trouble with my blower only working at high speed. My 2009 fit has less than 25000 and on a case by case basic Honda USA will consider "Goodwill" service for the TSB Technical Service Bulletin 09-097. That I found out through this site. No cost to me.
Thank you Fitfreak!
Old Aug 20, 2014 | 10:09 AM
medbill's Avatar
Sorry for not following up, they wouldn't cover it under warranty but they did recharge it with a dye for a little over a hundred bucks if I remember right. They said if the ac stops working and some parts are needed it would be covered. So far this summer it has worked fine and blew nice and cold.
Now if the service manager would call me back about my cracked arm rest as he promised I'd be doing great. I think I might pull the door skin and epoxy the split. That should fix it.....
Old Mar 20, 2016 | 01:21 AM
Sheldonsmith's Avatar
Just had the same problem with my AC- the blower was actually running
with no air coming out of the vents, then air started coming out at room temp.Then i contact AC SERVICE CYPRESS,they do excellent work.Actually they are experts and high technicians.
Old Jun 8, 2018 | 06:58 PM
Joshua Daniel Bruner's Avatar
Question Similar A/C issues...
I have a bit of a Fit problem... My A/C is out and I need to fully diagnose the issue. I tried recharging with R134a and when I was about halfway through, the compressor started cycling (I had the car on with MAX A/C) and I heard a pressurized leak accompanied with a leathery smell. Is it the compressor coils or just the A/C tube itself? I need to know the exact part I need to purchase to DIY. Any advice is much appreciated!
Old Nov 22, 2023 | 11:33 PM
honda599's Avatar
Originally Posted by irontmp
Hello - I have a 98 Montero Sport. Yesterday morning my AC blew cold as it always does. I commute 45-60 each way in Dallas traffic and it always blows cold even in July heat. Yesterday when I left work I noticed it was not blowing cold. It felt like it was blowing the same temp as the outside temp. I checked the fuses and they were not blown. I had the A/C condensor, receiver dryer, evaporator core, and expansion block changed out 4 years ago to the tune of $1300. The car is not behaving the same way it did that time. (I have had other cars with slow or fast leaks and you can generally tell when it is going to go out. That time it had lots of leaks and would initially blow cold and then get hot.) I made the mistake of buying a Chilton subscription only to find out that they don't have any A/C info for my vehicle. There is some note that AC repair should only be performed by a certified tech. I just wanted something to help me know what might be wrong so I don't get ripped off at the repair shop. Chilton is a ripoff. I'm trying to educate myself before I go to the mechanic. Any ideas what might have caused the previously great running AC to just stop one day? Thanks, Blackcloud
There is a bank of 3 relays located in engine compartment drivers side which control AC fans and compressor. It is quite common for compressor relay to fail causing intermittent AC operation to none at all. You can test by swapping relays but be careful as other relays control cooling fans so not for super long when testing.
dosbirn
Sep 17, 2024 08:59 AM
dayshay
Mar 31, 2018 02:38 AM
Fit?
Dec 14, 2016 11:18 AM
jy1129
Jul 30, 2016 09:59 PM
SheepNutz
May 17, 2014 11:34 PM
