Check Engine Code : P0171
Old 09-21-2012, 07:00 PM
Fit*est's Avatar
Question Check Engine Code : P0171
Came on out of nowhere today, Only mod I currently have is a T1R axleback.
P0171- Bank one to LEAN.
Cleared it w/ the scanner.
Didn't have any noticeable issues. - What should I do?
Old 09-21-2012, 07:09 PM
Wafulz's Avatar
hmmm scary how many miles u got check ur EGR
Old 09-21-2012, 07:10 PM
Fit*est's Avatar
just under 20K
its a 2010 Sport 5spd
Old 09-21-2012, 07:12 PM
Wafulz's Avatar
shit dam crazy for it to go lean and u dnt got a intake right shit u make me worried now lol hahaah i got 2012 sport 15k miles nothing worng so far i hope lol i got intake and greddy axel back i clean ym filter every oil change
Old 09-21-2012, 07:14 PM
Fit*est's Avatar
I had an intake on it. but put the stock back in like 2 months ago.
Old 09-21-2012, 07:16 PM
Wafulz's Avatar
Probable Cause:
Large vacuum leak
Fuel system concern
Igntition system concern
MAF sensor faulty
H02S/AF ratio sensor fault" cuz thats what usually causes it
Old 09-21-2012, 07:17 PM
Wafulz's Avatar
disconnet battery see if it goes away : / if not might be maf : / i hear alot about them being sens dam i should go bak to stock lol
Old 09-21-2012, 07:19 PM
Wafulz's Avatar
also dubble check house make sure everything tight dubble check maf make sure it snug
Old 11-08-2012, 11:45 AM
bonylad's Avatar
something is loose or was loose behind the maf. a connection or hose is loose/not connected/split. its letting unmetered air into the motor the maf isnt accounting for, the motor is running lean as a result. given how crammed everything is in that area.....thats your issue.
Old 11-08-2012, 03:43 PM
Black3sr's Avatar
Did you by this car with no wty? If not take it to the dealer.
ecoterragaia
12-12-2013 11:36 AM
superdat1
03-23-2012 12:25 PM
superdat1
03-23-2012 03:07 AM
Pang3t
09-22-2011 08:50 AM
FELIXY69
02-27-2009 03:41 PM
Quick Reply: Check Engine Code : P0171
