Turn Signal Issues -HELP-
Old Mar 6, 2014 | 07:26 PM
fawbusha's Avatar
Exclamation Turn Signal Issues -HELP-
So I have Depo tails and stock fronts. Recently my driver side rear turn signal has stopped working and my front driver side signal blinks really fast. I'm thinking that there is a ground somewhere. Does anyone know where to look first? Has anyone had this problem? It's pretty annoying...
Old Mar 6, 2014 | 09:18 PM
Goobers's Avatar
Usually if a turn signal bulb burns out, the remaining bulb (for the same side) "hyperflashes" as an indicator to the driver: "time to replace a bulb."
Old Mar 7, 2014 | 03:59 AM
Black3sr's Avatar
Correct. Cheap easy fix
Old Mar 7, 2014 | 12:09 PM
Subie's Avatar
Old Mar 7, 2014 | 11:34 PM
fawbusha's Avatar
But the thing is that the rear is not burned out.
Old Mar 8, 2014 | 03:35 AM
Black3sr's Avatar
Did you check the right one? It is the one with TWO elements - one for stop and one for signal. If not then give it a try and replace. Just swap it with the other side to check it.
Old Mar 8, 2014 | 08:41 PM
fawbusha's Avatar
Well everyone was wrong lol. It was a loose connector. (I suppose you were all kinda right since the car thought a bulb was out)
Old Mar 9, 2014 | 05:05 AM
Black3sr's Avatar
Yes but when you went to swap them the problem got solved so... sort of right.
connor55
Oct 11, 2015 09:12 PM
WhiskeySix
Mar 24, 2014 07:57 PM
thefit09
Aug 9, 2012 05:36 PM
sav_fitatsos
Oct 20, 2010 11:02 AM
EXWRX
Dec 4, 2007 12:52 PM
