Replacing both cracked fog lamps on 2013 sport
Old Jan 8, 2016 | 10:46 PM
jy1129's Avatar
So I finally got around to ordering a pair of depo replacement fog lamps from Amazon.com to replace my cracked fog lamps.
www.amazon.com/gp/aw/d/B00XDDISFK/ref=ya_aw_oh_bia_dp?ie=UTF8&psc=1
I'll be adding lamin-x to protect from rocks and maybe a mesh overlay. Does anyone else have experience with the depo fog lamps? I thought the cover would be glass like oem but they are plastic.
Old Feb 8, 2016 | 02:27 PM
jy1129's Avatar
So after getting the fog lamps prepped for the install using laminx and a plastic mesh grill, turns out the lamps ARE THE WRONG ONES! Had to return them... they were smaller in size, probably for the 09-11 Fit Sport. I had looked them up using what I thought was the correct part number.
Where has everyone else gotten their replacement fog lamps from? Don't want to go through that again.
Old Feb 8, 2016 | 02:51 PM
xxryu139xx's Avatar
Theretrofit source sells LED replacements that will fit the 12+ fogs and cheaper than OEM
Old Feb 8, 2016 | 02:56 PM
jy1129's Avatar
I want to stick with OEM style fog lamps since I will be installing an HID kit.
Old Feb 8, 2016 | 05:05 PM
dwtaylorpdx's Avatar
If your going to do HID fogs, then buy the correct housings, the stockers are not correct for HID..
Old Feb 11, 2016 | 02:08 PM
jy1129's Avatar
I decided to return the HID fogs and go with the morimoto LED fog lamps... didn't want the hassle of finding a set of fog lamps again. Anyone have pics of them installed and lit up?
Old Feb 11, 2016 | 04:02 PM
xxryu139xx's Avatar
here is mine with laminx yellow
Attached Thumbnails Replacing both cracked fog lamps on 2013 sport-img_1852_zpsamkc17bs.jpg
Old Feb 16, 2016 | 02:01 PM
jy1129's Avatar
Thanks! Looks good!
Old Feb 28, 2016 | 01:32 AM
jy1129's Avatar
Finally got them installed... added clear lamin-x and a plastic mesh grill on top for extra protection.
Attached Thumbnails Replacing both cracked fog lamps on 2013 sport-image_efea3f24d957fe6c0cec7a596d9ca3d37af69697.jpeg
Old Sep 20, 2016 | 01:30 AM
Zero_Cool's Avatar
would you say that they are as bright as stock?
Old Sep 24, 2016 | 09:10 PM
jy1129's Avatar
They are brighter and the beam is more focused.
medbill
Apr 30, 2014 02:06 PM
Red 05
Dec 8, 2011 04:45 PM
cold_ukranian
May 17, 2010 10:07 AM
Tounge73
Jan 31, 2009 11:39 PM
Shaggs2Dope
31
Dec 30, 2008 12:13 AM
