Can We use Antenna Power Wire as Remote Turn On?
Old Feb 21, 2013 | 10:44 AM
BMW ALPINA's Avatar
Hi,
I got one question,
Did the Antenna Power Wire from Honda Stock Head Unit turn on only when you are listening to radio, or it also turn on when you are listening to CD/AUX?
The reason I ask this is because I want to use this Antenna Power Wire as Remote Turn On for My Powered Subwoofer.
and I want the Sub to be Turn On not just on radio but also on CD/Aux mode.
oh, and by the way, I have not check the wiring directly, but is the Antenna Power Wire on the factory wiring have BLACK cable color? can someone here pointed out which one is the Antenna Power Wire on the Factory connector?
Thanks
Old Mar 14, 2013 | 02:19 PM
BMW ALPINA's Avatar
I found out about this answer myself,
Yes, we can use the Power Antenna remote as REMOTE ON for Power
Amplifier or Powered Sub-woofer.
But take note that the Power Antenna Cable is NOT at the main socket,
but at the other smaller socket together with the Antenna Signal Cable.
Old Mar 14, 2013 | 05:02 PM
funny you mentioned this cause often times i need to use the remote wire as 12v power for the antenna booster (the exact opposite) to get clear FM reception.
Old Mar 14, 2013 | 05:26 PM
BMW ALPINA's Avatar
Hi Kenchan,
Are you using this remote wire for the Factory Antenna Booster,
or you add aftermarket antenna booster ?
If you are using this for factory antenna booster, then Tapping (just tapping and not cutting the power to factory antenna booster) this wire for Power Amp remote on should not be a problem,
because the remote on function of Power Amp/Powered Sub only draw negligible current so it should not be a problem... and not interfere with the factory antenna booster function, at least my current FM Reception is still the same as before
Old Mar 18, 2013 | 03:33 PM
yah, usually i use the blue/white remote wire for the antenna booster, and any triggers such as remote e-brake bypass, etc.
NjBlazin07
Feb 15, 2020 05:20 PM
vwli
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Oct 4, 2013 07:43 PM
vwli
Jun 25, 2009 09:41 PM
GodSpeed
Jun 19, 2009 04:24 PM
jvm051
Aug 4, 2008 12:14 AM
