Kevin's GE8
Old Mar 22, 2019 | 11:45 PM
  #101
USDM's Avatar
Relatively self-explanatory addition here...
I mostly like them because they keep the reservoirs clean; makes servicing the brake/clutch system that much easier.
Old Apr 16, 2019 | 03:37 AM
  #102
USDM's Avatar
Replaced:
- spark plugs
- valve cover gasket
Cleaned:
- throttle body
Also, adjusted the valve clearances. Engine is very smooth and the valves are really quiet which kinda surprised me to be honest, but I'm happy. I wasn't expecting that much of a difference.
Old Apr 22, 2019 | 09:14 AM
  #103
fujisawa's Avatar
How long does it take to get access to the valve cover? More worried about that than the actual valve adjustment 🙄
Old Apr 22, 2019 | 12:58 PM
  #104
Alfa38's Avatar
It's not that bad, maybe an hour or so to remove everything. I did the job on Saturday, probably took about 4.5 hours total, and I work very slow and carefully, particularly with the valve adjustment.
Old Apr 22, 2019 | 03:36 PM
  #105
USDM's Avatar
You sound just like me, haha.
Old Apr 23, 2019 | 10:56 AM
  #106
fujisawa's Avatar
I was thinking of buying a 4x6 canopy in case it goes long. This is our main car so certainly I would need to complete it over no more than a day+
Old Apr 23, 2019 | 01:14 PM
  #107
Alfa38's Avatar
No reason you couldn't put the cowl and intake parts inside the car and just close the hood overnight, if you had to. Canopy would only be needed for sun or rain (although you could plan around that, too).
Old Jun 19, 2019 | 11:17 AM
  #108
eulogy's Avatar
car lookin real clean
how do you like the mugen pedals? i thought about getting some for my a/t but envisioned that texture stuff on the pedals coming off and making a mess on the carpet. or getting loaded with dirt/shoe stuff.
i see you swapped your cupholder. if you dont want the original one anymore lmk if you are interested in trading it for an intermittent wiper stalk!
Old Jun 23, 2019 | 02:32 AM
  #109
USDM's Avatar
Thanks! The Mugen pedals are nice. The texture has not come off, but you can totally see which sections of the pedals are used the most due to heel-toe downshifting. I'm not really sure how I'd clean them, but I don't really care to anyway. I'm hanging on to the OEM cupholder, sorry.
Old Jun 23, 2019 | 05:51 PM
  #110
USDM's Avatar
@eulogy, this is what the pedals look like currently after ~7,000 miles of usage.
Old Jun 24, 2019 | 09:07 AM
  #111
eulogy's Avatar
nice thanks for the info n pic. they barely look dirty...and good to know the texture isnt doin weird stuff
Old Jun 24, 2019 | 12:58 PM
  #112
USDM's Avatar
I would expect nothing less for their price tag, haha.
Old Jul 27, 2019 | 05:25 PM
  #113
USDM's Avatar
Tein Flex Z coilovers, J's Racing tie bar, and ITR brakes installed. I also added a bit more negative camber, so the car is sitting at -2.5 degrees of negative camber at the moment. I also gained an entire degree of caster which was nice; kept the toe at 0.00.
Old Jul 29, 2019 | 10:15 AM
  #114
evilchargerfan's Avatar
where does the j's racing bar install to?
Im jealous of the tein flex z. mine only allow me to go so low, until you start ruining preload / adversely affecting ride quality and handling (thread type is the worse, I wish they all just came fully adjustable)
Old Jul 30, 2019 | 01:01 AM
  #115
USDM's Avatar
I picked up the coilovers for $100. They ride extremely well and, dare I say, better than stock.
Old Jul 30, 2019 | 05:25 PM
  #116
that is a crazy good deal
AH, that lower control arm brace. I took mine off temp, I can def notice a diff (I tend to under steer alot now)
Old Jul 30, 2019 | 05:47 PM
  #117
USDM's Avatar
Yeah, I couldn't pass it up for that price. My front sway bar is disconnected currently as I don't have the Tein end links and the OEM end links are a tad too long; understeer has drastically been reduced and the car is way more fun to drive now.
Old Jul 31, 2019 | 08:07 PM
  #118
Fourunnerguy's Avatar
The stock wheels have really grown on me since I've lowered my car, you make me want to buy better tires! I love your stance! I apologize if I missed it, what size tire did you end up going with on your RE-71R?
Old Aug 1, 2019 | 01:49 AM
  #119
USDM's Avatar
Thanks! The stock wheels get the job done just fine. I'm not really invested in this car too much and I intend on keeping it that way. I really want an S2000 or to build a 92-95 Civic hatchback since that was my first car and I've had a soft spot for them ever since.
Tires are 205/50/16 square setup which retains a ratio very similar to the factory-sized tires.
yovtecjustkickedin
Dec 31, 2016 09:59 PM
Topher
Mar 15, 2011 11:14 AM
phuccer
Sep 23, 2010 05:49 PM
Black01
Aug 26, 2010 06:00 PM
qbmurderer13
Jan 27, 2009 10:10 AM
