Springs/Shocks to go with Progress Rear Sway Bar
Old Mar 8, 2019 | 03:26 PM
Zardiw's Avatar
Hi all.
Got a 2013 Fit......btw...they call it a Fit cause everything fits......even an 8Ft Step Ladder......lol.
Going to install the ProgressAuto Rear Sway Bar, and thought I'd replace the springs/shocks while I'm at it.
I don't want to lower it at all....but I'd like it to not bottom out when I hit a dip at speed, so looking for something strong and high quality.
Will replace the fronts down the road a bit, but for now will just do the rears.
Any suggestions?
Thank you
Old Mar 12, 2019 | 01:04 PM
fitsmyfit's Avatar
Originally Posted by Zardiw
Hi all.
Any suggestions?
Thank you
If you're looking to keep the same ride height, just replace the OEM struts with either Koni Oranges or KYB's and fit them with the stock struts.
If you ever plan to go lower; Swift springs will give you a slight drop of 1.2in and can work with any replacement strut as they are designed to perform well with OEM strut/shock specifications. I have been running my Fit with Swift springs paired with KYB struts. I have no problems with bottoming out even on large bumps and still have enough clearance to put snow cables on my tires. Swifts springs have eliminated most the body roll and increase the handling characteristics without sacrificing the ride quality.
Mazubo
Aug 25, 2017 09:17 PM
badass8
Dec 29, 2016 04:06 AM
yovtecjustkickedin
Apr 6, 2015 02:17 AM
Marian
Jan 25, 2010 03:07 AM
ride_the_pony69
May 29, 2007 12:03 AM
