GE8 Lowered Thread - Post your pics!!!
Old Mar 6, 2012 | 11:34 PM
  #1321
ge8killa's Avatar
droppin it more this weekend! cant wait!
Old Mar 7, 2012 | 07:31 AM
  #1322
Chad T's Avatar
Little negative camber would probably fix that.
Originally Posted by lowkeymods
Yeah, I only get that when I'm doing crazy stuff. I usually drive like a grandma. So you think no rolling/liner modification needed?
They do poke a few mm outside of the fender (+40 offset):
Old Mar 7, 2012 | 08:36 AM
  #1323
jbyron's Avatar
17x7 +40 on 205/40/17 and Tanabe DF210s. No rubbing whatsoever. -2.25 camber up front, stock in the rear
Old Mar 7, 2012 | 09:32 AM
  #1324
Speedlimitz's Avatar
Looks good , are those motagi's? Love the finish.
Old Mar 7, 2012 | 11:37 AM
  #1325
jbyron's Avatar
thanks! yes, they are motegi sp10s in hyperblack
Old Mar 7, 2012 | 07:36 PM
  #1326
NewFitGuy09's Avatar
Originally Posted by SSMTEN
question... are you using lugs with conical seats on your stock wheels? those looks like extended a/m lugs
^ his question!? Also where did you get them?
Old Mar 8, 2012 | 12:56 PM
  #1327
SSMTEN's Avatar
I ask, because using "tuner lugs" with cone shaped seats on oem wheels that use ball/flat seats is dangerous.
Also, if you are looking to aftermarket lugs, pretty much every parts site you can think of has them.
Lug Nuts - JHPUSA
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Lug Nuts / Locks
Products - Assaultech Performance - Aftermarket Performance Parts at a Discount - Free Shipping on Orders Over $100
LUG NUTS :: ACCESSORIES :: WHEELS :: weksos industries
Old Mar 8, 2012 | 01:48 PM
  #1328
^ how bad is it to aftermarket lugs on oem wheels?
Old Mar 8, 2012 | 02:18 PM
  #1329
SSMTEN's Avatar
There are different styles of lugs. You cant mix and match with wheels. You could do damage to both the lugs and wheels. Worst case scenario, the lugs could back off and you could loose your wheel.
just get the right kind
Old Mar 8, 2012 | 02:20 PM
  #1330
doctordoom's Avatar
Supervillain
^ It's about this much bad. Give or take an inch or two.
Just kidding, now I'll try to answer your question seriously.
It's bad because the aftermarket lug nut doesn't seat correctly against the OEM wheel. They're simply different shapes. Here found a picture:
If you really want to use aftermarket lug nuts on your OEM alloys, you could get adapters/washers to convert the seat.
Old Mar 8, 2012 | 02:23 PM
  #1331
Personal experience:
Guy who bought my 91 Civic Si put the Muteki's from my SSR's on to the stock wheels.
The wheel came off at speed.
Old Mar 8, 2012 | 02:28 PM
  #1332
ThEvil0nE's Avatar
this bad...
even KICS has no match for oem wheels...
there is of course a solution if you intend to run tuner lugs on oem wheels... ADAPTER WASHER TO CONVERT 60 DEGREE TAPER LUG NUT
Old Mar 8, 2012 | 02:33 PM
  #1333
Ok so what kind of lugs would you recommend for the stock sport rims? Round?? I don't want my wheels to fall off lol
Old Mar 8, 2012 | 02:37 PM
  #1334
Could adapters be bought elsewhere like at pepboys or autzone?
Old Mar 8, 2012 | 02:44 PM
  #1335
Good lugs for stock wheels? Stock.
Old Mar 8, 2012 | 02:50 PM
  #1336
ThEvil0nE's Avatar
^what he said
Old Mar 8, 2012 | 03:29 PM
  #1337
MEATBABY's Avatar
Yes the oem wheels take round or ball seat lug nuts. I would agree, just use your stock nuts on the stock wheels. That adapter is interesting, but seems the tiniest bit unsafe. Probably fine though. I don't think there a lot of options for aftermarket ball seat nuts. If it's color that's bothering you, just take your lug nuts to a powder coating place.
EDIT: Well I guess there are some cheap ones on ebay in different colors...http://www.ebay.com/sch/i.html?_from...+ball+lug+nuts
Old Mar 8, 2012 | 04:06 PM
  #1338
Wanderer.'s Avatar
Hey, cool beans, I was wondering about this the other day, thanks for posting. Before I clicked the link I was worried about how thick the adapter was but it seems to be super-thin which is good as far as how much the lugnuts thread onto the stud.
I see people all the time with tuner lugs on stock wheels and I always hope you don't diaf
Hopefully they're using these and i'm just uninformed.
Old Mar 8, 2012 | 05:02 PM
  #1339
Would those eBay ball seat lugs be any good? Stripping, breaking off? Etc. the reason I ask is because i do want different color lug nuts but would like to keep the stock ones as back up or if I want to return to stock!
Old Mar 8, 2012 | 05:06 PM
  #1340
Are you that broke that you can't buy wheels?
