Spring Rates
Old Sep 13, 2009 | 07:34 AM
Lek's Avatar
Lek
Spring Rates
I notice that the Fit GE has spring rates of F1.7k / R 2.0k and the GD has spring rates of F 3.1 / R4.9.
When I bought my BC Coilovers for my GE the standard springs were F5k / R4k which I thought were going to be way too hard. Anyway, after fitting I found out that they weren't too hard just firm.
How come there is such a big difference in spring rates on the GE between Stock and my coilovers, but the springs don't feel it while driving.
Old Sep 13, 2009 | 02:38 PM
ToFit2Quit's Avatar
Not sure, but maybe the dampers on the coilovers compensate for the spring rate...
Old Sep 13, 2009 | 07:47 PM
shazaam's Avatar
if the dampers are valved for the springs it shouldn't feel like ish. n those aren't high spring rates by any means either.
Old Sep 13, 2009 | 08:40 PM
Lek's Avatar
Lek
Stock Fit GE has spring rates of F1.7k / R 2.0k vs BC Coilovers F5k / R4k.
That's over 250% harder.
Old Sep 15, 2009 | 03:10 PM
wow, the GE's stock sus feels more like 5k front 6k rear.
you sure about 1.7k and 2.k? that's awefully low.
Old Sep 15, 2009 | 09:42 PM
Type 100's Avatar
I think Lek is correct on that.
If you look around researching spring rates for aftermarket components on the GE, most lowering springs and street-use coilovers have really low spring rates vs. the GD, and they don't really increase all that much from the GE stock spring rates. I guess it is due to the GE's greater torsional rigidity, allowing for softer springs.
But yeah I get what you mean. I test-drove a GE6 and didn't feel like its ride was improved over my GD1 on 16s. Must be down to the dampers then?
Old Sep 15, 2009 | 10:07 PM
Lek's Avatar
Lek
I think with my BC coilovers it's down to the damping force. On settings 4 or 5 they feel better than stock, but if I adjust to 9 or 10 they're very firm, anything above that will break your back. I've never had them on setting 30.
Old Sep 16, 2009 | 12:36 PM
interesting interesting...
Old Sep 16, 2009 | 07:33 PM
Texas Coyote's Avatar
These are real stiffly built little cars..... In the old pre unit construction days if you were to stiffen your suspension the chassis would flex so much you could see the front fenders undulating when driving on a bumpy road.... That was the reason for wide gaps between the front doors, fenders and hood on high performance muscle cars.
Old Sep 17, 2009 | 10:07 AM
TheFitman's Avatar
"high performance muscle car" is an oxymoron
Old Sep 17, 2009 | 12:18 PM
Not all high performance cars were categorized as muscle cars and most of the muscle cars only offered performance in a straight line for 1320 feet.... That is what it was all about back then.
revd34
Jan 9, 2021 02:03 PM
pig_pit
Apr 6, 2012 03:41 AM
jmag310
Mar 5, 2011 05:48 AM
El Chupacabura
Jun 19, 2010 10:13 PM
wontfit
Apr 20, 2008 10:55 PM
