2010's come with rear swaybar?
Old Oct 24, 2009 | 10:06 PM
ej96hatch's Avatar
I just picked up my 2010 sport yesterday. I looked under the rear of the car and did not notice a rear swaybar! On Hondas website it shows the specs on the fit (base/sport) and it shows the sport as having a rear 17mm swaybar! Is it hidden or should it be in plain view? Thanks in advance!
Old Oct 24, 2009 | 10:14 PM
dela's Avatar
its not really a separate part.. its integrated within the torsion beam...
Old Oct 24, 2009 | 10:25 PM
ej96hatch's Avatar
Ok. So if I were to add a progress 19mm rear swaybar would I have to uninstall the factory bar some way? If not what would combining the 17mm stock with the 19mm progress rear swaybar do as far as handling?
Old Oct 24, 2009 | 11:05 PM
Chad T's Avatar
Sport sway is inside the beam and welded to the ends. Would be hard to see form underneath.
Old Oct 25, 2009 | 09:49 AM
ej96hatch's Avatar
I saw that bar running across and figured that's what it was! So if I were to buy the progress swaybar, I assume it would mount up to the bottom of the spring seats correct?
Old Oct 25, 2009 | 10:14 AM
Chad T's Avatar
The GD bars mount that way. I haven't seen an installed pic of the GE progress bar but the ultra racing bar mounts to the trailing arms which should be a simpler install. I thought somebody was making a smaller (16mm) bar to go better on the sport which already has a sway bar.
https://www.fitfreak.net/forums/gaug...-sway-bar.html
Old Oct 25, 2009 | 10:23 AM
ej96hatch's Avatar
The ultra racing one looks similar to the progress one: The Progress Group - Anti-roll bars Honda Fit 09-10 Honda Fit Rear anti-roll bar
Old Oct 25, 2009 | 10:52 PM
ekonetics's Avatar
I'm running the 19mm Ultra Racing Rear Sway Bar for months now and enjoy every minute of it. They offer both the 16mm and 19mm. The 16mm is for the US market while the 19mm is for the other GE's. I have no experience with the 16mm and since Progress was going with 19mm I just opted for the same.
Old Oct 26, 2009 | 08:03 PM
ej96hatch's Avatar
How much difference in handling did you notice when you added the UR 19mm sway?
Old Oct 26, 2009 | 08:33 PM
ekonetics's Avatar
I noticed a significant difference over stock.
Old Nov 3, 2009 | 04:33 AM
macbuddy's Avatar
...this RSB sounds like a simple mod...
ej96hatch
Here is a thread that might answer these questions for you. Take a look at these posts:
Review of the Progress Rear Swaybar for the '09 Fit
The Install of the RSB, with pictures
To my knowledge, this was the first production '09 Progress RSB shipped to the general public.
Old Jan 6, 2010 | 07:33 PM
BakedCookies's Avatar
I am running the Progress sway bar with the sport factory sway bar, turn in on the car is greatly improved with a nice heavy feel/response to the steering wheel.
I would recommend!
Old Aug 18, 2010 | 03:35 PM
Committobefit08's Avatar
I too am running the Progress sway...I agree with Baked 100%.
Significant difference in handling.
Old Nov 29, 2010 | 01:55 AM
phenoyz's Avatar
i have an '09 base
will the 19mm fit into a base '09?
can u give the website where u bought the ultra rear sway bar
DOES the '09 Base come w/ a stock rear sway bar?
thNKS
Old Nov 29, 2010 | 02:22 AM
Occam's Avatar
The base doesn't have a sway bar, but a twist beam by nature has the same effect as a sway bar.
It's so amazing to think that even the cheapest car in Honda's line can be had with front and rear sway bars... and 16" alloys for that matter.
Old Nov 29, 2010 | 02:35 AM
ekonetics's Avatar
Originally Posted by phenoyz
i have an '09 base
thNKS
The UR rear sway bar will fit a base model. I sold mine to another member on this forum. When I purchased my bar it was through another member on here who was helping out the distributor for Ultra Racing. I know they have a few dealers around if you search.
Old Nov 30, 2010 | 12:12 AM
Leets's Avatar
i have an '09 base
thNKS
I have a 10 Base which also does not have a stock bar. I recently installed a Progress bar, and it made a HUGE difference in the driving characteristics of the Base. The Base model's love of understeer is dramatically reduced. Go buy one NOW!
Old Dec 19, 2010 | 09:29 AM
High Velocity's Avatar
Originally Posted by macbuddy
ej96hatch
Super helpful links especially the review. Thanks!!
Mikeyk12
Jan 22, 2013 11:01 AM
jcalhoun
May 18, 2012 04:59 PM
Chad T
Apr 13, 2012 09:34 AM
cargun
Nov 3, 2009 04:25 AM
JWB
Jun 24, 2009 09:09 PM
