10mm vs 15mm spacer
Old Jun 5, 2013 | 06:56 PM
ciref8's Avatar
10mm vs 15mm spacer
I got my rears rolled due to rubbing with 5 people in the car. Now the rear has some minor pull that comes with rolling the rear
here i have the rear passenger side tire sitting on a few blocks of wood to get it to compress a bit. you can see from the scrub marks where it did rub at full compression pre fender roll
its about half an inch clearance so i'm thinking 15mm coupled with something like this Suspension fixes. Rear too low. Rubber spring spacers. - AudiWorld Forums might help with the low rear spring rate. (2.5k vs 2.0k stock)
10mm spacers are also an option but would require extended studs and open ended lugs or oem 96 3.2 tl studs in order for me to use my current lug nuts.
Old Jun 5, 2013 | 07:04 PM
Wanderer.'s Avatar
What suspension are you running?
Old Jun 5, 2013 | 07:26 PM
ciref8's Avatar
t1r s-coil springs. I would ideally have buddy club n+ but have not seen any for sale in a while.
wheels are 16x7 +40 on 205/50/16 falken 512
Old Jun 5, 2013 | 07:49 PM
Wanderer.'s Avatar
With spacers total offset is +25?
Not sure if putting blocks on one side will give you good measurements either, because the wheel won't be straight like it usually is it will lean in when it's pushed, look at the diagram, second picture.
Twist-beam rear suspension - Wikipedia, the free encyclopedia
When you're driving and both wheels hit a dip they'll remain with no camber, so it'll throw your measurements off. Put some heavy stuff in the back instead.
Stance and lowering springs usually don't mix well, especially when you have a packed car. You could try those spring spacers to bring the car up a little bit but I don't think it will be enough to stop it from rubbing on big dips with weight in the back with soft spring rates like you have. It might help with smaller bumps.
I vote 10mm spacers and extended studs. That way if you still have issues with 10mm you can go down until it doesn't rub anymore.
Or take the spacers off until you can get coilovers.
Old Jun 5, 2013 | 11:56 PM
ciref8's Avatar
Oh wow, I didn't think about the rear twisting. I ordered the oem studs 10mm spacer so we'll see how it'll work out in a few days.
thanks.
Old Jun 6, 2013 | 12:28 AM
solbrothers's Avatar
no, no it doesn't
liverpoolfcfan
34
Sep 30, 2013 11:14 PM
SenBlue09
Feb 13, 2012 12:55 AM
Scala
Jan 8, 2012 03:03 PM
gnuman05
Jan 1, 2012 08:35 PM
prossett
Mar 14, 2008 01:29 PM
