PILLOW BALL TOP MOUNTS Useful?
Old Apr 13, 2014 | 04:57 AM
camivill's Avatar
Is this useful?
From Japanparts.com
Material: Body: Super-duralumin A2017. Bearing: The spherical bearing(MBWT18) is used by the Minebea Company. Bearing case and Nut & collar: Steel (S45C). For Honda OEM shocks and springs. By without using rrubber bush which is supporting the bearing and making a top mount a solid suppression, useless movement of shock absorber is lost and sharp handling is achieved. Moreover, by adopting pillow ball for the bearing and making working of the suspension smooth, a performance the suspension original comes to be demonstrated. It is a design where height doesn't go up, and the original size shock absorber and the use in spring become possible, too. The width of the setting extends because the suspension of the height adjustment type doesn't sacrifice the stroke. BOLT ON.
Old May 20, 2014 | 10:19 AM
for street imo, it's better to use the factory bushings. some pillow mounts have excessive noise. it is a wear item and depending on how intensely you use it on the track, you will need to replace them as with bushings.
i had pillow mounts on my other cars running coilovers. they have a direct feel, but not sure if it's worth the extra especially for street use. i mean a lot of folks use crappy tires to begin with, and the sidewall distortion kinda defeats the purpose...
Old May 22, 2014 | 08:26 AM
camivill's Avatar
Thanks
Thank you for the info!
skiboarder119
Jun 12, 2022 10:23 PM
ewong12
14
Jan 11, 2012 01:38 AM
patyong
Jun 18, 2011 11:38 PM
JaWade
Jun 17, 2010 06:14 AM
SHG_Mike
May 2, 2008 06:28 PM
