GE Fit Sport with 15" wheels/tires?
Old Mar 29, 2011 | 02:13 PM
Blackbeard's Avatar
Question GE Fit Sport with 15" wheels/tires?
Has anyone downsized their wheels to 15" wheels?
It seems like they are cheaper and lighter.
They wouldn't handle as well as the 16", but might give a more comfortable ride.
Old Mar 29, 2011 | 03:39 PM
thaduke2003's Avatar
There's no reason why you couldn't- the base/Sport calipers and rotors are the same, so they'll fit, as long as your backspacing/offset matches up. Not to say they won't handle as well as 16's, but you add sidewall and remove solid metal, which adds compliance in the wheel/tire setup. I'd rather have a bit more sidewall and a lighter wheel/tire combo, as taller tires won't cook as quickly as lower-profile tires on the track. Also, lower unsprung weight pays greater dividends than lower sidewalls, within reason. Keep it 55-series and under, and you'll be fine.
Also, make sure your overall diameter stays close to stock (24.0-2" should be fine)- Mark W.
Old Mar 29, 2011 | 04:02 PM
runbikerun's Avatar
I have 15's and I think they actually improved handling. I have some TireRack brand 15s with blizzaks for winter and Mini Cooper wheels for summer. 195/60/15 tires.
Old Apr 14, 2011 | 02:17 PM
Coppatop85's Avatar
Does this mess with the odometer at all when you change tire size?
Old Apr 14, 2011 | 03:04 PM
Blackbeard's Avatar
Cool Not
If you use the same outer diameter tire.
I ordered some rims off EBay and plan on having them powder coated purple metallic to match the BBP...
Bought 195/60R-15 Yokohama AVID ENVigor's from Tirerack to put on it...
24.2" outer diameter...
Yokohama AVID ENVigor (H&V)
OEM 16 inch Dunlops-24.2"
Dunlop SP Sport 7000 A/S
slinginit
Aug 30, 2017 08:29 AM
johnoshea
Mar 9, 2015 03:33 AM
x_25
Jan 31, 2012 04:59 PM
lnarngr
Aug 25, 2010 01:12 PM
der Mond
Oct 4, 2007 02:27 AM
