Opinions/Advice on this setup...
Old Jul 31, 2011 | 12:30 PM
lowkeymods's Avatar
Drag DR-33's
Width: 7.5"
Bolt Patern: 4x100
Width7.5″
Would this setup work w/ Swift springs as far as rubbing?
Would 17"s make my car sit too high and look like a monster truck?
Do black rims on crystal black pearl look wierd?
Here's my baby as she sits now w/o springs (Swifts to be installed this week)
Thanks!
Old Aug 1, 2011 | 09:26 PM
Hootie's Avatar
Depends on what tire size you will use with those wheels. If you use what is recommended for that size (205/45R17) then you may experience some rubbing once lowered due to a combination of the wheel's offset (+42 mm in this case), wheel width, tire width and the tire's outer diameter which would likely cause the rear tire to rub on the bumper tabs. That is a fairly easy fix though; either shave the tabs down, cut them off completely and zip-tie/screw the bumper on at a new location, or just let it rub till it doesn't any more.
I'd wait for a GE owner or two to chime in with their thoughts on this though before making any official decisions just yet.
Old Aug 2, 2011 | 03:28 PM
Honda neewb's Avatar
Yea I'm hoping someone chimes in on this too. There is a set of xxr wheels that have similar specs. Curious to know same answers.
Rob H
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Apr 26, 2019 11:20 PM
Shanz
Mar 26, 2014 12:21 PM
xonexlifex
Apr 25, 2012 12:29 PM
lowkeymods
18
Mar 14, 2012 04:31 PM
ThEvil0nE
Jul 26, 2010 01:24 AM
