Just ordered my wheels! Need advice
Old Jan 30, 2012 | 10:40 PM
Sooner97's Avatar
Hey everyone, I just placed an order for some new Volk C28N 8 Spoke in Titanium Silver 16X7 +42 offset. They should get here within 6-8 weeks. My next decisions are tires. I'm leaning towards getting some all summer tires for the Volks, like the Yokohama S Drives 205/45/16. I plan to keep the stock 16 with the Conti DSW tires on them to use as snow tires if need be. I live in Dallas so we only get 3-4 days of snow most of the winter and the snow usually disappears a day later. What do you think about my plan? I know a lot of people like the DSW but does anyone have any info about the S Drives? I'm lowered on Swift Springs so I believe that the 205/45/16 shouldn't give me any rubbing problems, right?
Old Jan 30, 2012 | 10:51 PM
Hootie's Avatar
Depends, what year or chassis is your Fit?
Old Jan 30, 2012 | 10:52 PM
Sooner97's Avatar
Oh, sorry. It's a 2012 MT Fit Sport in TW.
Old Jan 30, 2012 | 11:07 PM
Hootie's Avatar
Its ok, we just need that to clarify though.
I wouldn't think so since the GE8's factory tire size for 205s is 205/50R16s, you'll be running the smaller diameter 205/45R16.
Never the less, its a good chance that there will be some tire rub due to tread width and wheel offset since GE chassis is a bit more "sensitive" to those two key elements... or more rather the combination of the two. Now with that said, this is with the early pre-Minor Model Change GE8s. I honestly do not know if the wheel tubs have been altered to allow lower offsets/wider tires.
Old Jan 30, 2012 | 11:11 PM
Hondafrk's Avatar
Don't know how much the swifts lower it, I have the Eibach pro kit on my '09, same size & offset wheels with 205-50's and I get a little rub on hard bumps. Been meaning to install camber bolts but of course never have. You may get lucky with the 205-45's, do let us know what happens.
Old Jan 30, 2012 | 11:15 PM
blassty's Avatar
There's this no rubbing / yes rubbing thread about Swifts that may help. https://www.fitfreak.net/forums/2nd-...ire-specs.html
Old Jan 31, 2012 | 02:52 AM
MNfit's Avatar
You will be fine with that set up. I have the same wheel/tire size combo and I am a hell of a lot lower then you probable are. I only rub on the front a little with hard bumps or turns, I also have a GD so you will be fine.
oiric2006@gmail.com
Apr 27, 2018 09:00 PM
comatoast
Nov 10, 2014 05:25 PM
FIT-tles Worth
Jul 13, 2012 02:34 PM
JaxAttaxx
Sep 1, 2011 12:58 PM
Vtecguru
Aug 4, 2011 08:59 AM
