how would these fit ?
Old May 29, 2012 | 12:35 PM
linnboi's Avatar
Old May 29, 2012 | 12:57 PM
krunk13's Avatar
Too wide and too low an offset. You might be able to make them fit but it would require lots of mods. coilovers,max camber,rolled fenders....etc
Old May 29, 2012 | 01:02 PM
linnboi's Avatar
stock wheel is 16x6.5 , 114x4 , offset ? right ?
what size can you go without modifying ... camber etc...
Old May 29, 2012 | 01:12 PM
krunk13's Avatar
Stock is 16x6.5 4x100 +53 offset. Most go with 16x7 or 17x7 with a 45 mm offset and have no problems.
Old May 29, 2012 | 01:42 PM
bmxman's Avatar
wow you were actually considering a 9" wide wheel??? You can run anything from 15"-18" wheels just make sure the off set is at least 40...there are many variables though.
Old Jun 11, 2012 | 10:33 AM
cokeismetal's Avatar
i have the rota j mag's 15x7 +40..... howcome the front pokes? i dont even have them on my car cuz i was gonna get 195.50 tires but they stuck out too far..... whats the ideal tire size? its also lowered and can go lower once i put those wheels on.
Old Jun 27, 2012 | 01:41 AM
flip's Avatar
This... I just tried some 16x7 +40 and the fronts poked so I ended up not buying. It wasn't just because I tried them with a 205/50 tire either, when we put just the wheel on after removing the tire the wheel itself pokes, looks good if anyone wants to roll their fenders though, just not me...
Old Jul 15, 2012 | 12:25 AM
ohanahuichubbz's Avatar
15x8 +25 is doable....
i roll on 18x8 +25 and 18x9 +35 just fine.. =)
Old Jul 20, 2012 | 12:20 AM
slp950's Avatar
You can run wider and lower offset with the right tire, provided you get your math right.
I'm running 17x7.5 et 35 with 205/40-17 Falken Ziex ZE512 in the front, and 17x8.5 et48 with 8mm spacer and 205/40-17 Falken Ziex ZE512 in the rear.
Just an FYI, 18x8 et45 rubs with 225/35-18 nankangs.
What size tires are you running? They are probably too wide. The wheel definitely isn't poking with that width and offset.
Car is looking sick! 5 lug swap too man, crazy!
And not everybody is willing to camber and roll/pull fenders...
Weds Kranze Cerberus... so baller dude...
Old Jul 20, 2012 | 12:43 AM
They're actually works euroline s2. Thanks though.
mikeGe82012
May 28, 2017 12:11 AM
billyb
May 15, 2010 01:55 PM
Blueputtputt
Apr 29, 2010 12:55 AM
rvall004
May 20, 2008 04:08 AM
FireFit
Sep 13, 2006 03:38 PM
