16 x 8.25 with 0 offset
Old Mar 16, 2013 | 04:12 AM
hatchpat's Avatar
Any ideas on how this size would look (16 x 8.25 with 0 offset) on a 2010 fit?
Will they work?
Cars dropped with tein springs, will have coils at some point!!
What size tires would work best to 1) fit best or 2) stretch if needed?
Thanks
Old Mar 16, 2013 | 12:55 PM
ThEvil0nE's Avatar
with over fenders and modding it should work. no over fenders, something like this...
Old Mar 16, 2013 | 01:36 PM
DreaMv's Avatar
wont look good unless theres alot of work done to the fenders (rolling/pulling/trimming), camber, ultra dumped, and tire stretch.
stick with something like +20 if you want to do low offset with less headache of fender modification/rubbing everywhere you go
Old Mar 18, 2013 | 04:40 PM
Nickocosmic's Avatar
Mine with 16x8 +25 on 225/50's, lowered on B&G S2's. Fenders rolled and pulled front and rear, front fenders spaced out about 3/4 inch; cambered up front like -2 degrees or so (I think):
Rubs constantly. Had to remove the B&G's and put the stock springs back in. You probably won't be able to pull it off on springs, you'll more than likely need some nice stiff coilovers. Springs allow too much suspension travel. Also, stretched tires like others have said.
Old Jul 12, 2013 | 10:37 PM
Dizin's Avatar
I say no, I ran +25's for a while and was disappointed with look and I had the fenders rolled way out over stock. To be even further out than dude above you would want some over fenders which would be hard to pull off. Even if they were an awesome deal, I would save for something less aggressive. GL dude.
Old Jul 17, 2013 | 02:35 AM
Phyrric's Avatar
This is the exact wheel fitment I want, minus the mudding tires
Old Jul 17, 2013 | 05:59 AM
onetwothree's Avatar
Tires too big that's all if little smaller would b flush ^^
Old Jul 17, 2013 | 09:20 AM
solbrothers's Avatar
the tires wont change anything except how close the car is to the ground.
Black3sr
Jul 1, 2013 01:32 PM
HONDAMATIC
Jan 10, 2010 03:23 PM
revd34
Oct 18, 2009 07:30 AM
1500cc
Aug 16, 2008 04:04 AM
TiMo
Jul 21, 2008 10:55 PM
