Will 14x7, +40/+31 fit?
Old Apr 1, 2013 | 12:20 PM
Floral Drapes's Avatar
There's a set of panasports for sale locally, 14x7 with staggered offset: +40 and +31. They should clear the brakes although I'm not sure about the offset. Anyone have any input?
Old Apr 1, 2013 | 12:59 PM
Run a 185/60/14 and you'd be fine.
At least, I'm about 96% sure you would be.
Old Apr 1, 2013 | 02:28 PM
They have 195/60 Z1s mounted on them, probably the only reason why I'm considering them.
Old May 1, 2013 | 07:00 PM
slp950's Avatar
You shouldn't have any issues. Check out my build thread link in my sig, I ran 14x6 with like a 10-20ish et and 185/60-14s with zero issues. I have also ran quite a few more aggressive setups with no problems either, so I'm sure you'll be fine.
Old Jul 12, 2013 | 11:01 PM
Dizin's Avatar
The 31's will sit right at if not a little outside the fender which is a tough look to pull off. Trust me, I did it for a year and it bugged me every time I looked at them.
Old Jul 13, 2013 | 02:21 AM
GoFits's Avatar
had 14's with +35 offset. (Bottlecaps)
best to put the +31 offset up front...otherwise you WILL rub on the rear fenders with every bump you go over.
mikeGe82012
May 28, 2017 12:11 AM
Happy__Fit
Jun 16, 2010 01:19 AM
jazz_do_it
Apr 28, 2010 09:21 PM
sbualuba
Jan 31, 2009 02:04 PM
rvall004
May 20, 2008 04:08 AM
