Going from Stock Sport Wheels to Wider Wheels
Old Apr 29, 2014 | 06:51 PM
Bama3Dr's Avatar
I know a lot of you guys have experience with this and am just curious, would going from the stock sport 16x6 wheels to a 16x7 or 17x7 aftermarket wheel with 205 width tires greatly decrease the rolling over feeling that I get with 205/50/R16 tires on the stock narrow rims? Maybe it's just the tires I'm running (Kumho PA31 205/50/R16), but the "driving on a water bed" feeling when doing quick directional changes is starting to annoy me. I also feel that the car would be much more stable and less affected by wind on the interstate if this was improved. Thoughts?
Thanks guys,
Dustin
Old May 5, 2014 | 10:11 PM
Bama3Dr's Avatar
Anybody?. In the last few days I have tried airing my tires up to 42 psi. It definitely helps the rolling off the rims feeling, but at the expense of ride quality.
- Dustin
Old May 6, 2014 | 02:21 AM
zilla8's Avatar
I know exactly what you are talking about.I ditched the stock Dunnies after just a couple thousand miles of owning my 12 Sport.
I went with the Kumho 4X in 205/50 and they would roll over when pushed in the corners.I could see the wear at the outer edges of the tires.
I think a 16x7 is ideal for the 205 but of course this set up can get a little heavy.
I got just over 40K out of the 205 Kumho tires and I just went back to my stock 185/55 Dunlops.I think I will go with the Hankook V2 in a 185/55 when the Dunlops wear out.
I've decided to stick with the stock sport wheels and I see more choices coming down the line in the odd 185/55/16 size.
Old May 6, 2014 | 05:28 AM
Black3sr's Avatar
I just put these on. 16 x 7 General Exclaims UHP 205 50 16 . The offset is only 40 so I do get an odd rub on severe bumps. I am on Swifts as well. A nice solid feel.
Old May 6, 2014 | 08:08 PM
zilla8's Avatar
Looks good and I love my Swifts too.I would like to get a nice set of wheels but the roads are so bad in my area that I just do not want to do it.
I would be so pissed if I bent a expensive new rim hitting a pot hole.I like your set up and those wheels look good on your TW Fit.
Old May 8, 2014 | 02:08 PM
Waiz's Avatar
Avid FitFreak Poster
Thanks for posting up pics, I am definitely going to upgrade to 205's for my next set of tires.
I am on 195-50's but want more of a meaty look for my SSR's
I just ran a comparison vs my current setup and was given the following:
Tire size calculator
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
195/50-16 3.8in 11.8in 23.7in 74.4in 852 0.0%
205/50-16 4.0in 12.0in 24.1in 75.6in 838 1.7%
Slightly larger sidewall and slightly larger overall size but better selection of tires from what I am seeing on Tire Rack
I like your Sport wheels better than the version that is available for the 09-11, if you like them then keep them!
andre181
Sep 29, 2015 08:45 PM
B Fit
Jan 15, 2013 01:36 PM
FitVic
Jan 13, 2010 05:10 PM
Pursang
Mar 1, 2008 01:13 PM
squareback
Aug 3, 2007 07:06 PM
