3rd Gen GK Specific Fit Engine Modifications, Motor Swaps, ECU Tuning Sub-Forum Threads discussing engine mods/swaps/tuning for the third generation GK Honda Fit.
LrpTec Automotive aerodynamics - Cold Air Intake
Old Jul 7, 2019 | 12:31 PM
Myxalplyx's Avatar
So what do you guys think? And how about that front grille that allows all that cool air to come in. I know it's not usable on our platform (Maf sensor?) but it's eye candy.
Old Jul 7, 2019 | 09:29 PM
robertsmithfromthecure's Avatar
Wow, that is wild.
Old Jul 7, 2019 | 10:29 PM
Rap SantOs's Avatar
To have a noticeable effect for performance you need to pressurized the intake manifold greater than normal earth air density like how turbo and sc compresses air,, a cone intake wont get this job done as cone filter slows down air flow,, better design are ram scoop intake of crz and gk as it scoops air and presses it into the intake manifold. Those chambered intake with short tubes are the best intake then do this grill shield seen here to isolate engine hot air from the intake
Old Jul 8, 2019 | 12:54 PM
evilchargerfan's Avatar
it looks the part
I wish these guys would be more up front about their pricing, instead of doing the whole "PM US FOR PRICING" thing that they are presently doing
Old Jul 15, 2019 | 03:26 PM
t-rd's Avatar
Having installed multiple intake setups in the past on different Honda's, the only good setup I ended up with is the OEM setup. Retain the OEM air box, chop off the intake resonator with the tube still in the bumper then install a K&N drop-in filter. Unless you are moving, heat soaking in traffic is worse with aluminum tubing than rubber. It's a HOT air intake, not cold air intake, not practical for daily use.
Ba_forareason
Jun 25, 2018 01:31 PM
Myxalplyx
Sep 27, 2014 11:31 AM
mhopper
Mar 9, 2011 08:34 PM
clanbuster
Oct 14, 2010 11:19 PM
zombi
Jun 21, 2007 02:35 PM
