3rd Gen GK Specific Fit Engine Modifications, Motor Swaps, ECU Tuning Sub-Forum Threads discussing engine mods/swaps/tuning for the third generation GK Honda Fit.
2016 HR-V AWD Transfer Case
Old May 11, 2015 | 03:19 PM
Myxalplyx's Avatar
Will it fit the 2015 Honda Fit?
No-one probably knows now but just putting this out there for anyone who may come across this information and knows. Thanks!
Old May 12, 2015 | 11:33 PM
wonton2049's Avatar
That would be an awesome swap.
Old May 13, 2015 | 01:34 AM
kylerwho's Avatar
spoon fed
With the past of Honda parts somewhat fitting, I would sat that transfer case will mount up in the fit about as easily as a CRV transfercase mounts in a b swapped civic.
Old May 13, 2015 | 09:07 AM
Bassguitarist1985's Avatar
If it was able to be installed on a FIT, could it be done with a 6MT? Something to think about too. I mean if Subaru's can have manuals and AWD why cant a Honda?!
Old May 13, 2015 | 12:04 PM
Redd's Avatar
If you could somehow fit it in there how would you control it???
Old May 13, 2015 | 12:33 PM
DWils's Avatar
With your right foot, duh!
Old May 13, 2015 | 05:29 PM
+1!! No need for this fancy computer stuff! Give me a manual transfer case shifter to put it in 4WD or 2WD. Contrary to most people in the States, I know how to drive a car, and operate one! :-P
Old May 13, 2015 | 07:36 PM
Redd's Avatar
Well now that you put it that way it sounds like a piece of cake!
Old May 13, 2015 | 09:15 PM
kylerwho's Avatar
spoon fed
well for those that don't know, Im going to say the "Honda AWD" runs either a viscious coupler or an electronic coupler that transfers power to the rear when slip is detected in the front via abs sensor.
We don't get the same awd as Subaru or Mitsubishi.
b&c performance is running a Honda element transmission with a custom straight shaft for their drag car.
Old May 14, 2015 | 07:54 AM
DWils's Avatar
And AWD is not the same as 4x4. I learned that one the hard way while off-roading with my brother in his Jeep Liberty while I was in my brand new Element.
Old May 14, 2015 | 11:10 AM
Good point. Its part time vs full time 4x4 which is one difference. AWD vs true 4x4, I'd choose mechanical manual 4x4 selection. Full time is the way to go. AWD to me is more trouble than its worth with all the extra tech required to manage it.
Old May 14, 2015 | 12:00 PM
TofuShop's Avatar
^Correct. Honda "4wd" isn't fulltime and is electronically controlled when it senses slip.
Most notoriously, there was a recent test showing how Honda 4WD doesnt even work properly:
I'd suggest skipping this as a mod.
Old May 14, 2015 | 09:09 PM
kylerwho's Avatar
spoon fed
I wouldn't say skip it. I would just eliminate the electronic coupler and run a custom straight shaft to make it full time awd.
Old May 14, 2015 | 10:14 PM
Myxalplyx's Avatar
Honda CR-V 2014 4WD failure - YouTube
^^^^THIS was a VERY convincing video. Thanks for the post! I still own two Subarus. I better stick with them for AWD.
Old May 14, 2015 | 10:34 PM
Lol AWD.
10char.
Old Nov 17, 2015 | 01:09 AM
Myxalplyx's Avatar
Propeller Shaft
So is this the piece I am looking for? I linked it up with the word 'Propeller Shaft' above. It's from the 2016 LX HR-V AWD (HondaPartsNetwork)
Old Nov 17, 2015 | 05:57 AM
kylerwho's Avatar
spoon fed
That is part of the equation.
curious if you could save money by just ordering the transfer case, transmission housing(instead of the full hrv transmission), propeller shaft, and rear axle assembly?
Here is the more important part you want to look at.
AT TRANSFER for 2016 Honda HR-V
Here is more interesting parts, it seems the rear differential is activated based on oil pressure much like a viscious coupler, but this is controlled via an oil pump #22 rather then fiction heating the oil up.
dampcurse
Sep 4, 2019 01:30 PM
Reddogs
Jul 22, 2016 02:57 AM
idletickover
Sep 14, 2015 05:09 PM
Fitmo
Feb 18, 2015 08:33 AM
DArkk
Nov 20, 2014 11:51 PM
