3rd Gen GK Specific Fit Engine Modifications, Motor Swaps, ECU Tuning Sub-Forum Threads discussing engine mods/swaps/tuning for the third generation GK Honda Fit.
DIY: Shifter Cable Bushing Upgrade
Old Jul 25, 2017 | 08:17 PM
nisco's Avatar
DIY: Acuity Instruments Shifter Cable Bushing Upgrade
If you're looking at this section of the forum, there is good chance that you already know that the stock shifting mechanism on our cars are mediocre at best. They weren't developed with performance driving in mind. I will be showing you how to install upgraded GK5 shifter cable bushings by Acuity Instruments. They have designed a kit with a custom acetal and aluminum spherical bushing so you can experience a solid, smooth shift that will make you fall in love with your car again.
After installing the the bushings, you can immediately feel the lack of slack in the cables, and crisp stops of shift knob movement going from gear to gear. Before installation I could feel the cable stretching after going into gear probably due to the rubber flexing in the stock bushings. There is still play with the shift knob in-gear but that is mainly due to the stock shift assembly.
Tools Required:
-Philips head screw driver
-3/8" 10mm socket
-3/8" Rachet with extension
-Duckbill pliers
-Adjustable wrench with circular jaw
Procedure:
Step 1: Disconnect negative terminal on battery with 10mm just to be safe.
Step 2: Remove the stock air intake box There are two air ducts up front, one clamp on re-circulation pipe, one clamp on throttle body, two green clips for MAF sensor wire, MAF sensor connector, and two 10mm bolts holding down the intake box. When removing the re-circulation pipe, be careful not to disconnect the pipe behind it. It contains coolant to cool the throttle body (don't ask how I know..)
Step 3: Once you have the airbox out of the way, you should be able to see the transmission with two cables with round ends attached on top. Remove cotter pins from stock rubber cable bushings.
Step 4: Using an adjustable wrench with a circular jaw, hold the circular cable ends firmly while using a screw driver to carefully pry out the stock rubber bushing without bending the cable itself.
Step 5: Closely paying attention to direction, press the Acuity bushings in until flush with cable end. Attach the supplied rings and cotter pins.
Step 6: Install airbox, connect MAF sensor, negative terminal, and don't forget to reset your clock.
Enjoy!!
Old Jul 25, 2017 | 11:02 PM
nisco's Avatar
Thanks Andrew! Let me know how the Hasport mount feels, I've been itching to try that next!
Originally Posted by idroveacamry
nice write up i might have to check this out after getting the hasport rear engine mount
Old Jul 26, 2017 | 01:57 AM
TougeMonster_GK5's Avatar
I have the U70A mount installed, and car feels like a race car now. Engine response improved dramatically, can tell thru the shifts..
Old Jul 26, 2017 | 01:58 AM
And nice write up btw! This will def be a bear future mod.. still need to install my EBC rotors and pads, ss lines, motul fluid... pushing for this week!!!
Old Jul 26, 2017 | 11:59 AM
nisco's Avatar
How's the vibration with the 70A? I was thinking about 62A since its still my daily, but if it's bearable I may go with 70A.
And thanks! Just trying to give back to the community I've learned a lot from. I REALLY need to address the brakes too.. Soo mushy it' s borderline scary hahaha
Old Jul 26, 2017 | 04:52 PM
The vibration was a little intense the 1st 2 weeks, now that im at week 4, the vibration has settled, and i think its bearable. One more level up and it might get really annoying. I say U70A it!
And yes, our stock brakes sucks. I was just about to get my EBC pads/rotors TechnaFit Ss Lines installed until the shop owner mentioned that switching to dot 4 would be a bad idea since it is impossible to gell all dot 3 out of the ABS system. I might have to just stick to Honda Dot 3 :/
Old Jul 27, 2017 | 05:56 AM
n9cv's Avatar
You got some BAD information there.
DOT3 and DOT4 are compatible and mixed together or interchanged all of the time. Read the can labels or on the Internet for more information.
The biggest difference between DOT 3 and DOT 4 is it's wet boiling point. On a small car like a FIT I doubt that you will be concerned with wet point numbers.
Do NOT use DOT 5. It is not compatible with DOT 3/4.
Old Sep 1, 2017 | 05:34 PM
WagovanMan's Avatar
Excellent write-up, nisco. I appreciate it very much. It inspired me to purchase the bushings and attempt the DIY.
I was unable to complete the job once I got to the stock bushings. I understand your instructions, but need a little more clarification:
I started with the larger of the two bushings and it seems like I need to slide the stock bushing (inside of its circular cable end) up and off the center spindle so that I have enough leverage to push and pry the bushing up and out, but my concern came from your warning not to bend the cable at all. Does sliding the bushing up and off its spindle bend the cable with that up and down movement, or did you mean not to bend the cable laterally (in a left/right direction)?
Also, do I really need a circular jaw wrench to hold the circular cable end or can I hold it by hand?
Any and all help is appreciated!
Old Sep 1, 2017 | 05:58 PM
nisco's Avatar
Thank you for your kind words WagovanMan.
Im currently at work but hope this quick sketch will help you out. In short, yes I'd reccomend using the jaw pliers to prevent loosing grip when holding with your hands. The bushings are pressed in with more pressure than our hands can handle lol
Old Sep 9, 2017 | 05:37 PM
WagovanMan's Avatar
Thanks nisco! Great success.
Just a disclaimer for anyone interested in this upgrade;
If you already have a rear mount for your GK5, you might not notice much of a difference after the bushing upgrade.
Don't get me wrong, I do notice improved motion from the shifter, but I think it would be even more dramatic if I didn't have the rear mount.
Good investment either way because it's relatively inexpensive and easy enough to DIY.
Old Sep 9, 2017 | 07:39 PM
USDM's Avatar
Thank you for documenting your installation and sharing it with us!
Old Sep 14, 2017 | 02:24 PM
DannyJ7's Avatar
Just put mine on...with the Buddy Club short throw, it's a hoot!
Old Sep 16, 2017 | 10:48 PM
CodemanGK5's Avatar
Just installed my Acuity bushings yesterday, feels great now! Can't wait to pair them up with a buddy club short throw shifter!
Old Oct 6, 2017 | 12:32 AM
[LegenD]'s Avatar
Thanks for sharing this awesome DIY ! Greatly appreciate it. Hoping to do this mod sooner than later.
Old Oct 10, 2017 | 10:30 PM
roksta's Avatar
Thanks for the write up! I was about 2 seconds away from pulling the coolant line before I saw this. The bushings are a great improvement too.
Old Oct 21, 2017 | 01:44 PM
Scruffy's Avatar
Dude! What a great upgrade, I'm so happy i came across this post. This is going to make shifting so much fun again haha
Old Apr 30, 2018 | 04:38 PM
evilchargerfan's Avatar
will be attempting this install in a few days .... wish me luck all
Old Jul 15, 2019 | 09:56 AM
silverrose12's Avatar
sorry to beat the dead horse, but if anyone has installed it, would you be able to let me know if its worth $74 ?
Old Jul 15, 2019 | 11:09 AM
it makes for a "clicky" feel when shifting
I was able to achieve that feel even more, with a new weighted shifter
IMO, it was not worth the $74. If I had to buy a 2nd GK5, I would skip this mod and apply that $74 elsewhere
Old Jul 15, 2019 | 11:16 AM
i see i see.. that's wot i saw in some review also ... i guess i'll just wait for short throw shifter that may or may not come out hhahahahahah
mole177
May 28, 2009 08:04 PM
accordguyintake
Feb 24, 2008 06:01 PM
pastafarian
Nov 20, 2007 05:27 PM
07fitsport
Aug 15, 2007 10:04 PM
Gordio
Dec 21, 2006 11:14 PM
