3rd Gen GK Specific Fit Engine Modifications, Motor Swaps, ECU Tuning Sub-Forum Threads discussing engine mods/swaps/tuning for the third generation GK Honda Fit.
Weapon-R Secret Weapon Intake (301-175-101)
Old Aug 7, 2018 | 01:38 PM
DannyJ7's Avatar
any suggests on a decent place to find said tubing?
Gosh, it'd like be a bit pricey anywhere but Summit should have some. Just make sure you measure what you need carefully. ID 4" gets pretty dicey.
Old Aug 7, 2018 | 01:46 PM
DannyJ7's Avatar
When I get home tonight I'll get out in the g-rage and take some measurements too. I may yet hold on to foxy... I'll share what I find.
Old Aug 7, 2018 | 11:35 PM
Myxalplyx's Avatar
Originally Posted by DannyJ7
That's exactly what I was getting at. Highly suggest finding a way to mitigate water inlet though... Also if you're serious about it making much of a difference don't use the provided accordion tube. Get some silicone tubing.
Damn it, where was this piece when I needed it? Had to cut a hole in a piece I ordered.
He should be cool as far as water ingestion goes since he'd just be connecting the hose part to his filter. The surrounding filter medium will always be pulling in air from the surrounding air filter area. If water starts to get pulled up through the foglight, it's likely the intake wouldn't have enough pull because of the filter allowing air to come in through the engine.
Just picture his setup generally being another version of AEM's Air Bypass Valve. His setup is virtually the same thing.
evilchargerfan
Aug 6, 2018 02:13 PM
Myxalplyx
Apr 11, 2015 09:56 PM
boyetssilverfit
14
Mar 21, 2013 12:39 PM
Cordizzle4life
Jan 5, 2012 11:50 AM
aliencowboy
Aug 17, 2008 12:47 PM
