3rd Gen GK Specific Fit Interior Modifications Sub-Forum Threads discussing interior modifications for the 3rd generation GK Honda Fit
Dash cam installed - no tools, no modifications
Old Oct 13, 2024 | 09:52 AM
  #61
3FITY's Avatar
Originally Posted by papagoose
Hi all, just to note that I wired up a dashcam today and removed the A-pillar cover on a 2018 Jazz to confirm exactly where the airbag is located. As shown in both photos, the airbag is not entirely contained within the headliner, nor is it entirely contained within the A-pillar. Instead, it extends across both. Therefore, routing the cable across the edge of the headliner using the OP's routing to get to the door trim means that the cable goes right over the airbag, obstructing deployment. To have a safe setup where the cable is entirely hidden, the cable needs to follow the existing electrical wiring at least until it clears the airbag itself. Personally I routed it as shown in the second picture (also worth noting that I disconnected the battery first)
thank you! I was looking for this information
Old Oct 13, 2024 | 10:15 AM
  #62
SilverEX15's Avatar
Nice job. I installed two separate fuse blocks in my Fit. One is powered directly y the battery, so power is always available. The other is powered by the car's fuse box. That's where I connected the dash cams. Instead of removing panels, I pressed with wire into the gap between the panels. I have Vioffo cameras front and rear. It's easy running the wire under the panels along with all the wires that run to the rear. I also installed a 12v power outlet in the rear.
KentFinn
Dec 29, 2016 07:24 PM
MTLian
Jan 25, 2014 03:54 PM
benmunger
May 17, 2011 07:52 PM
piauke
Jul 15, 2009 04:19 AM
FrogDaddy
Apr 26, 2008 01:33 PM
