3rd Gen GK Specific Fit Interior Modifications Sub-Forum Threads discussing interior modifications for the 3rd generation GK Honda Fit
DIY Footwell Lighting w/ Dome, Not Ambient
Old Jan 18, 2016 | 09:00 PM
tbFit's Avatar
Originally Posted by simonx314
I installed a switch that allows me to turn on my footwell lights while driving or toggle them to come on with the dome lights. Details in this thread:
https://www.fitfreak.net/forums/3rd-...de-always.html
Very nice writeup on the lighting mode switch!!
Old Aug 2, 2016 | 09:58 AM
DannyJ7's Avatar
Anyone know where I can get the connection that would allow me to actually plug this into that port?
http://cimg9.ibsrv.net/gimg/www.fitf...d2a5e329c5.jpg
My wiring keeps shaking loose and falling off the pins.
Old Aug 2, 2016 | 11:16 AM
tbFit's Avatar
I assume you've tightened up the crimps a few times? Mine went on very stiff and have stayed put for nearly 20k miles.
Old Aug 2, 2016 | 11:37 AM
simonx314's Avatar
Instead of using the positive pin, I used a $5 fuse tap which is a very secure connection. I only have to worry about the black wire coming loose, but it hasn't come loose at all for the 6,000 miles I've had it wired. Use a flattened molex connector, that is slightly too flattened to fit over the pin, so that when you force it over the pin, it is squeezing the pin tight. Then I taped down the wire so that pulling on the wire would hopefully not pull on the molex connector.
I wrote instructions about using a fuse tap here:
jl0r
109
Jan 6, 2019 07:52 AM
DannyJ7
Jan 15, 2015 05:16 PM
Gojulas
Jul 14, 2012 03:52 PM
connor55
May 20, 2012 04:37 AM
Roger's Fit
Oct 31, 2009 02:23 AM
