3rd Gen GK Specific Fit Interior Modifications Sub-Forum Threads discussing interior modifications for the 3rd generation GK Honda Fit
Rear trunk cargo cover
Old Apr 16, 2017 | 08:11 AM
NLEPATHY's Avatar
Hi I need some help.
I need a rear trunk cargo cover for my FIT 2015 hybrid. The problem is that my car trunk is not fitted with the two side rails to support the cover like with other FIT. Check my car trunk photos and the trunk available for Honda FIT.
Any advice on how to sort this out?
Genuine OEM Honda Fit Black Cargo Cover 2015 - 2017 | eBay
Attached Thumbnails Rear trunk cargo cover-img_20170416_152430.jpg   Rear trunk cargo cover-img_20170416_152436.jpg   Rear trunk cargo cover-img_20170416_152403.jpg   Rear trunk cargo cover-img_20170416_152447.jpg
Old Apr 16, 2017 | 01:20 PM
TorontoBoy's Avatar
The two side panels can be removed. Make custom rails and attach the rails from the inside. Then reinstall the two side panels. Does Honda sell the two side rails?
Old Apr 17, 2017 | 07:48 AM
get rear tint and a black drape or table cloth or something black to cover ur valuables when needed. it works much better than the cargo cover and you have full access to your cargo space. those cargo covers take up too much room.
Old Apr 17, 2017 | 08:07 AM
wasserball's Avatar
I have a collection of airlines "blankets" that I have borrowed from a few international flights. They come in handy to cover up valuables or used as drop cloth to prevent luggage from scratching the car.
Old Apr 17, 2017 | 11:13 AM
2Rismo2's Avatar
What's that panel on the right side of the trunk area for?
Old Apr 17, 2017 | 11:39 AM
fitchet's Avatar
Frustratingly maybe I realize this isn't really an answer.
But if you really want a trunk cargo cover and aren't receptive to the idea of window tint or blankets, then I would think you have to become something of a Pioneer.
I would think "Something" could be created using cardboard, plywood, or other materials and careful experimentation.
But given the relative uniqueness of a Honda Fit Hybrid, if nothing has been created on the commercial level, and it looks like Honda did not put cargo cover in the design, then it's really all up to the DIY skills of yourself.
Maybe not a great answer.
Even though the transferable process would NOT be the same, there might still be benefit it seeing how other have made cargo covers for their regular "Fits".
That is in creating templates and material choices.
Since no place to really attach or lay...I'm almost thinking something light enough to be suspended using perhaps velcro. It would almost have to be a "Visual Blocker" only.
But good luck.
If you come up with anything decent, let us know.
Old Apr 18, 2017 | 01:38 AM
tsand19151's Avatar
But good luck.
Exactly what I did. Made a frame from wood strips. Glue and poster board from a hobby shop. Honda's is way over priced and it should come with the car. Anyway, mine came out better than I thought it would. May cover it with something soft at some point, but for now it gets the job done.
Old Apr 18, 2017 | 04:46 AM
n9cv's Avatar
Get some Black Styrofoam and cut your own. I have some black 1.5" stuff that I used to insulate a Hangar door. I picked it up from Michigan Foam Products which is a place that manufactures it in Grand Rapids, MI.
For as little as you need you could probably get a sample. One 2x8 sheet would be enough to make several of them or for several tries at making one good one.
Old Apr 18, 2017 | 09:01 AM
2Rismo2's Avatar
Like others have mentioned, a DIY solution is very economical. I made mine for less than $30. You can see some pictures here: https://www.fitfreak.net/forums/3rd-...ick-intro.html
I thought about getting fancy and using a retractable window shade. Have it mounted on the HB and connect it to the back of the headrest posts. Figured the HB could be opened and the cover would stretch out while it lifted. Since the rails weren't just straight, the had curves I nixed that idea. For you without the rails, maybe it's something you could look at.
Old Apr 18, 2017 | 02:42 PM
tsand19151's Avatar
HomeMade Cargo Cover
Total cost: about $30 (includes 2 test prototypes ) May cover it with something soft at some point.
Old Sep 24, 2019 | 07:49 AM
dsaint's Avatar
Hi,
I'm having this same issue. I bought the Cargo Cover and those plastic supporting side rails seems to be missing on my Hyrbid Fit. Did you ever find a solution? I'm thinking of putting in some kind of peg to hold it but not sure how to secure it through that felt.
Old Sep 24, 2019 | 11:59 AM
evilchargerfan's Avatar
you can try pulling up diagrams and sift through images and try to find that piece
https://www.hondapartsonline.net/v-2...ning--tailgate
(I took a quick glance, and was not able to find the 2 side pieces)
Yao Moua
Aug 15, 2017 09:55 PM
SilverEX15
22
Oct 28, 2014 06:49 AM
dave92029
Aug 28, 2014 07:04 PM
TommyMadison
Mar 19, 2014 11:41 PM
tivofanatic
Aug 9, 2013 10:27 AM
