How many miles will the CVT Transmission typically last?
Old Dec 28, 2024 | 06:48 PM
  #61
bill bosco's Avatar
Originally Posted by bobski
In the sense of static friction perhaps. Unlike a clutch, the CVT belt has no partial-engagement/slipping state. The belt is held taut against the pulleys at all times. The only slipping that occurs is when the pulleys are actively changing gear ratios. The pulleys are effectively changing diameter, and therefor the length of the pulley circumference that the belt is contacting. That should mean the portion of the belt contacting the pulleys needs to "stretch" or "contract" a bit as that change is happening. The belt is made of steel bands and segments, so it's not so good at stretching - more likely the segments will slip slightly on the pulley. Another possibility is the two halves of each pulley are engineered to rock slightly with respect to each other - to go slightly out of parallel so that the belt-entry side of the pulley is actually a different width (effective diameter) than the belt-exit side. This would let each successive belt segment contribute to a stairway-like formation as it goes around the pulley. The trouble with that: out-of-parallel pulley halves would have greatly reduced contact area with the belt segments (whose shape is cut to match the pulley vee), which would be its own potential wear issue.
It's unfortunate all the engineers have to sign NDAs - I would love to hear about the challenges and solutions of modern tech.
i guess only time will tell , seems like they are using them in some heavier vehicles lately . this is a good sign ?
Old Dec 31, 2024 | 07:51 AM
  #62
SilverEX15's Avatar
It's all a question of how it's designed and built.
Old Jan 22, 2025 | 02:10 AM
  #63
Gekisen's Avatar
Mine started feeling rubber bandy around 110,000 miles. I've changed the fluid twice; 40k and 80k
Old Feb 10, 2025 | 12:25 AM
  #64
Lucky_luke's Avatar
well, just bought a fit from scrap yard, 2015 find out that was a delivery compagnie that owned it before, 282000km / 175000mile. i flushed the tranny + changed the cvt filter to be sure to start brand new, and the oil was so brown almost like engine oil, no bad smell like over heat or something. tranny go reaaaaally well and smooth. i think it will last 500000km/350k miles if you flush regulary.
on the other hand can i have your version of bad injector , and what happen to the car (missfire or something) im deep in a diagnistoc for a p0420 and find out they have tsb for bad injector. but other then that car run really nicely and im not sure i want to change 4injector and a rail for like 1000$
Old Feb 10, 2025 | 08:54 AM
  #65
SilverEX15's Avatar
Good luck with that. I like to see cars restored and given a second chance at life. Unfortunately, replacement parts have gotten ridiculously expensive over the years. Have you considered getting a rebuilt engine for it? It would save you a lot of time and, possibly, money.
Old Feb 10, 2025 | 11:11 PM
  #66
Lucky_luke's Avatar
nah, engine go really too well for changing it. i dont care if the engine light is on i just want to find an cheap easy fix otherwise i will drive it with CEL on. i will try a injector cleaner and if its not working, an o2 spacer and let you all know if it turn off the light.
Old Feb 11, 2025 | 08:25 AM
  #67
SilverEX15's Avatar
Since the engine is good - don't mess with it.
victorgarage
Dec 5, 2022 02:22 AM
Liljpw16
Sep 30, 2019 03:27 PM
sanosuque
Jan 26, 2008 03:23 PM
kwest2bee
Feb 5, 2006 07:28 AM
