2015 odd transmission issue?
Old Mar 20, 2020 | 11:03 AM
Caffiend's Avatar
Hey guys,
Last night driving home from work my fit wouldn't shift into any gear on the bottom of the gate, gears 2/4/6/R. Manual transmission. The issue happened with the car running and not running. Then out of nowhere it stopped and started working fine. Any ideas? I plan on taking it in this weekend but figured I'd post here first.
Old Mar 21, 2020 | 09:48 AM
Fuelish's Avatar
Originally Posted by Caffiend
Hey guys,
Wow....I have no idea.....have driven manuals most of my life, including my '15 Fit LX, never heard of such a thing. Yeah, I'd get it looked at stat
Old Mar 21, 2020 | 11:53 AM
bargainguy's Avatar
So 1/3/5 are OK but 2/4/6/R are kaput?
If you can't shift into 2/4/6/R even with the engine off, something is blocking the lower gates. My guess is a mechanical obstruction, but caused by what? Misbehaving software?
Old Apr 8, 2020 | 09:44 AM
CommanderSlug's Avatar
I had the same issue on my 5 speed suzuki after I forgot to fill the transmission with oil. Suddenly I had lost access to gears 2/3/4 but 1 and 5 and reverse would work just fine. The loss of access to gears happened suddenly as I was pulling out of a parking lot & I could also not access them with the engine turned off... as if the syncros seized or something.
Old Apr 8, 2020 | 11:57 AM
ROTTBOY's Avatar
..............something is blocking the lower gates. My guess is a mechanical obstruction, but caused by what? Misbehaving software?
Agree!
Check the linkage first and around your shifter boot.
Old Apr 8, 2020 | 04:13 PM
2015FITEX's Avatar
here is a longshot..
usally there is sort of strut what keeps the shifter and the engine trans so they cant move independently, are the bushings worn(if we have such a thing)
Old Apr 13, 2020 | 01:14 PM
Caffiend's Avatar
Follow up with everyone on this thread. I have had zero shifting issues since this post. It happened that day for about 5 minutes and never popped up again. My local Honda shop is on some odd hours because of the whole COVID-19 thing, and I am still working full time so I haven't had a chance to take it in.
Old Apr 13, 2020 | 10:07 PM
Rob H's Avatar
As someone else said something was blocking it? It probably fell off? I had the same issue last fall and a squirrel had hidden a walnut on top of the transmission blocking the linkage.
bertosfit
Nov 15, 2018 06:43 PM
TripleP
Apr 21, 2018 04:29 AM
bklynrickel
Oct 13, 2017 07:34 PM
azopelnut
Jul 10, 2017 05:04 PM
1speedbike
Jul 13, 2015 10:01 PM
