P0685
I'm having the same problem. Just started today. suddenly loss of power just like the transmission suddenly shifting to neutral and then back into gear and alls well again......
Code that came out was P0685
I haven't sent my car in for checking yet.
2018 Honda Jazz GK5
2018 Honda Jazz GK5
Relay finally arrived and was swapped in. Same issue and same code showed up again about 25 miles after picking it up from the dealer. Short of replacing wiring harnesses that appear to be perfectly fine, I'm not sure what else can be done to fix this car... Really not looking forward to buying a car in this market, but I'm afraid that's the best option at this point.
2018 Honda Jazz GK5
2018 Honda Jazz GK5
It's been only 2 days now and so far, the car seems to drive as normal. I'll report back if the problem comes back.
Yup. Honda classifies fuel injectors as part of the emissions system, not the power train, which means they can skate away from the injectors after 3 years rather than the 5 year power train warranty. They like to brag about their 5 year power train warranty ("Honda Warranty Protection Makes Power Train Components a Minor Concern") but few customers realize up front that there's an awful lot of potentially problematic components (like the fuel injectors!) which are separated out into the emissions system and are only covered for 3 years.
can you share how much it cost? i had the same issue a few months back.
Go to 3 Motorwerkz at Kaki Bukit and get them to check. The bosses are Ex Kah Motor mechanics that ventured out on their own.
p0685 ecm/pcm power
gfrobe
Nov 21, 2020 01:37 PM
fuzzybabybunny
Mar 21, 2010 12:58 PM
