Rattling/Rumbling Noises
Old Apr 3, 2021 | 11:21 PM
Joseon's Avatar
Exclamation Rattling/Rumbling Noises
Hello,
I have a 2018 Honda Fit (Manual) with ~37,000 miles.
Recently, I noticed rattling/rumbling noises (it sounds like it's coming from the back of the car, but I could be wrong) when I:
  • start from a stationary position with 1st gear engaged (i.e. red light turns green and I accelerate)
  • make a turn (either from a stationary position or I'm in motion)
I think the suspect might be the transmission fluid. Would anyone have any other possible ideas of why this is the case?
Apologies if this is posted in the wrong spot, I'd be happy to remove and relocate this post to the right one.
Thank you!
Old Apr 4, 2021 | 01:26 AM
Fuelish's Avatar
If it sounds like it’s coming from the rear, start troubleshooting there... check suspension mounting points - the Fit has a simple rear design, although I doubt it’s coming from there given the circumstances you described... check your muffler mounting points, but from the sound of it, it could be motor mount or tranny mount... At your mileage, the manual gearbox fluid should still be good - I think Honda recommends change it every 60000 miles, iirc. I’d say motor or tranny mount... but I’ve been wrong before... more than once Good luck getting it sorted
Old Apr 4, 2021 | 08:26 AM
Ultrawolf's Avatar
Could it be as simple as a loose spare tire?
Old Apr 4, 2021 | 05:30 PM
Fuelish's Avatar
Good point... Could be, forgot to add that to my short list ....never had a loose spare, but have had the clamps of my jumper cables rattle back there - I "wrap" it around the spare - have ever since put an old heavy sock or glove or something on them to prevent metal to metal contact, works well enough
Old Apr 4, 2021 | 11:48 PM
CajunLanMan's Avatar
I started getting an annoying rattling several weeks after buying my new-to-me 2018 sport. Turns out it was the license plate I had just put on there days before. Seems when only the top screws are in, it rattles like mad. Good news is it was a simple fix of adding the two bottom screws (which did not come with the car).
phoenity
Oct 1, 2018 03:10 PM
gabriel0830
Nov 3, 2015 03:32 PM
lcq4blackstar
Jul 13, 2011 06:04 PM
160jimbo
Jun 7, 2006 11:58 PM
R. P.
Jul 1, 2005 10:58 PM
