Budget Build
Old Nov 15, 2021 | 10:58 PM
Erst's Avatar
Red face Budget Build
So I have a 2019 Honda Fit LX. I'm looking to either pimp it out or increase performance. I have around $300 to put in the build for now. Thanks for your responses!
Old Nov 16, 2021 | 11:58 AM
Done Deal DR's Avatar
Maybe a Progress rear sway bar and... generic front lip spoiler if one is available for the later facelift models? That would work out to be ~250 shipped. Or if you're mechanically inclined you could probably do lowering springs for about that amount.
Old Nov 17, 2021 | 10:52 AM
Fuelish's Avatar
Originally Posted by Done Deal DR
Maybe a Progress rear sway bar...
have one on my '15, I like it.....less understeer, unless it's all in my head Super easy install
Old Nov 17, 2021 | 11:42 AM
I agree, super easy install and it helped the understeer and also overall stability on the highway, less swaying side to side. I'd recommend it to anyone. I wouldn't say night and day difference, but definitely an improvement.
Old Nov 18, 2021 | 02:17 PM
Z062FIT's Avatar
Powerflex urethane bushings
One of the most underrated mods ever but really sets the car up nice. About $300 for front a arms and rear axle (whole car). And while you're at it, the Savanini rigid collars... camber bolts up front and shims for the rear are also cheap mods. The hfp shocks and springs are nice but I think like 600 bucks. Ktuner without the screen is like $450. The stage 1 tune really improves engine performance. Pedal commander is nice $300. Maybe a CAI $200. Acuity shift fork bushings are an easy mod if you have MT.
Old Nov 19, 2021 | 09:17 PM
ajpjive's Avatar
I've been considering the Powerflex bushings for a while now. How rough is the install? Worth the $300? Likewise, I'm planning to install HFP suspension here soon. It's a pretty subtle drop, but still a few centimeters. Is it worth getting roll center adjusters to go along with?
Thanks for your thoughts!
Old Nov 19, 2021 | 09:54 PM
I can't comment on the Powerflex bushings, however the HFP suspension is actually only a 10mm (1cm) drop.
Not that a small drop is a problem, but every roll center adjuster for the Fit I've seen is engineered to work with at least a 20mm drop at minimum. If you run them with only a 10mm drop you'd be out of spec the opposite direction. Can't comment on how big of a problem that may or may not be, but the manufacturers listings I've seen are very clear about it.
Old Nov 20, 2021 | 01:23 AM
If money is tight don't modify your car dude.
Old Nov 20, 2021 | 10:01 AM
ajpjive's Avatar
You rock, thanks Done Deal DR! I figured Honda wouldn't release something that would screw up suspension geometry too much, but I wanted to make sure I wasn't causing additional issues by installing HFP suspension.
I'd also echo the value of the Progress RSB. Can't go wrong there!
Old Dec 17, 2021 | 02:01 AM
BMWguy22's Avatar
Anyone have a reputable source to get the Savanini collars from?
The companies i find online (including Savanini) are quoting me about 400 for a set of collars?!
thanks in advance
Old Dec 17, 2021 | 11:08 AM
ajpjive's Avatar
thanks in advance
I went with the 'Magic Collar' brand collars from kanthachai on Ebay. These in specific: https://www.ebay.com/itm/324102015984. I'm quite happy with them. Real quick shipping and a decent price for the front/rear ($185 shipped). I've seen the Savanini collars on Aliexpress; it might be worth browsing there if you're looking for those in specific. If I recall, they're a tidge cheaper than the Magic Collar brand ones.
Old Dec 17, 2021 | 11:41 AM
Z062FIT's Avatar
tidge = 75%... I think the savaninis were forty bones off aliexpress. Reputable? Meh...
Old Dec 17, 2021 | 11:44 AM
ajpjive's Avatar
Hot damn, that's a heck of a jump. If I ever redo suspension work, I'll probably pick up a set of Savaninis. Seeing as they're basically just crush washers, I doubt there's much of a difference between the Savanini, Magic Collars, and Spoons.
Old Dec 17, 2021 | 12:26 PM
BMWguy22's Avatar
+1
I pulled the trigger on a set of Savanini's last night for $50cad shipped from AliExpress.
I didn't feel comfortable with using my CC number, so I paid with paypal
Gents, thank you for the replies.
jonaol364
Aug 29, 2018 03:14 PM
H741108
Toronto Community
Aug 3, 2015 01:58 AM
CrystalFiveMT
Nov 16, 2008 04:37 PM
saikit
Jul 21, 2008 06:09 PM
joebtfsptlk
May 31, 2006 02:18 PM
