Wiring for power windows drivers door?
Old Mar 5, 2022 | 11:33 AM
jonesym33's Avatar
I'm not able to find any wiring information. I am trying to lower the front driver's side window on a door that has already been removed from a car. I can't connected to a normal wiring harness so I would like to just try and put 12 volts to the proper pins to lower the window. Can anyone tell me which ones and which connector I should be connecting to?
Old Mar 5, 2022 | 07:33 PM
James Butler's Avatar
Try this . Looks like pin 1 and 2 on the connectors for motor connection
Old Mar 6, 2022 | 07:56 AM
jonesym33's Avatar
Thanks for this :)
It Would have helped. I ended up pulling the connection to the motor and pulled back the insulation to see the colors there. Then I reattached and connected the wires to the coupler to my Ryobi battery. I know it's too many volts but worked fine and a lot easier than messing with a car battery.
cakacon
Dec 5, 2018 10:18 PM
RestlessCA
Aug 30, 2018 09:55 PM
smitch
Oct 17, 2011 11:28 AM
CombatBaby
Sep 25, 2009 09:43 AM
HEMI-Fit
Nov 12, 2007 07:53 AM
