2015 EX Starting problem
Old Apr 18, 2022 | 03:40 PM
Robert Lecours's Avatar
Hello Fit specialists. I am looking for advice for a starting problem on my 2015 EX 38000Km. Sometimes it starts on the 1st shot and sometimes it takes several shots. It's not the battery and I've tested 2 starters, 1 used and 1 refurbished! Suggestions ??? Thank you!Hello Fit specialists. I am looking for advice for a starting problem on my 2015 EX 38000Km. Sometimes it starts on the 1st shot and sometimes it takes several shots. It's not the battery and I've tested 2 starters, 1 used and 1 refurbished! Suggestions ??? Thank you!
Salut les spécialistes de Fit. Je cherche des conseils pour un problème de démarrage sur mon 2015 EX 38000Km. Des fois il démarre du 1er coup et des fois ça prends plusieurs coups. Ce n‘est pas la batterie et ça fait 2 starters que je test, 1 usagé et 1 reconditionné! Des suggestions ??? Merci!
Old Apr 19, 2022 | 10:48 AM
BMWguy22's Avatar
Try running premium gas.
That's what I use in my FIT and it starts on the first crank.
Old Apr 19, 2022 | 11:13 AM
wasserball's Avatar
I see you have an EX, do you have the push start button? It may be the culprit as I have read in this forum. For me, I keep things simple. I have a LX. I start the car by twisting the key in the steering column, and I always use the cheapest regular gas available. With 104k miles on the clock, I never had a starting problem.
Old Apr 19, 2022 | 02:52 PM
bargainguy's Avatar
Welcome. I've long believed that on the pushbutton start Fits, the circuit design is inadequate to buffer the load at startup.
As a result, both the start switch and the starter are prone to premature failure, and often when one goes, it's ascribed to the other. Diagnosis roulette ensues.
According to recent reports here, Honda has started goodwilling the start switch, but not the starter.
You might want to check with your Honda dealer to see if they cover the start switch.
Old May 1, 2022 | 05:17 AM
3rdGenOwner's Avatar
I recently had a starter system issue that was not mechanically related. Plastic pieces that used to contact the sensors in my brake and clutch broke apart, so the vehicle prevented starting. I wrote a post about this issue
Old Sep 22, 2022 | 06:46 PM
ritholtz's Avatar
it might be starter problem. I paid $400 to replace starter for my 2015 fit.
Old Sep 24, 2022 | 03:27 AM
Chitown Fit's Avatar
Stait Button Needs To Be Replaced.
I had this same problem on my 2015 EX.
Honda has a recall free repair for this issue. Go to your local Honda Dealer to remedy this. Oh did I mention this is FREE!!!!!!!
Mke Fit
Upper Mid-West Community
Apr 19, 2023 12:20 AM
Garceman
Jul 19, 2019 04:41 PM
David Lawrence
Feb 26, 2017 11:05 PM
IQBALLK
Apr 14, 2015 09:42 AM
chazmr
Jul 2, 2014 07:02 AM
