Clutch Slipped At 84,000 Miles.
Old Jun 23, 2022 | 06:16 PM
Chitown Fit's Avatar
Just had my clutch, flywheel, pressure plate replaced on my 2015 EX 6 speed manual. Anyone else have or has had their clutch replaced?
Old Jun 23, 2022 | 07:51 PM
BMWguy22's Avatar
i'm only at 41k miles and have no evidence of slippage.
You sure it was the clutch and not just a hydraulic (slave cyl) issue?
Old Jun 23, 2022 | 09:12 PM
Clutch Slipping
It was the clutch. The last few weeks it got worse. It got to the point that my Fit would barely have any launch from a complete stop. It takes off great now that I had the clutch, fly wheel, and pressure plate replaced.
Old Jun 24, 2022 | 12:26 PM
BMWguy22's Avatar
Sheesh, that's harsh.
Glad it's worked out for you!
Old Jun 24, 2022 | 05:09 PM
Fuelish's Avatar
wow.... have never needed a clutch over the lives of several manual cars.....my '15 Fit has about 73;000 miles on it and is tight enough to stall in a heartbeat if ya have the radio too loud and aren't listening to what the engine's doing. Have driven previous cars harder, my old'75 Celica went 160.000+ on original clutch.
I bet the new one feels great
Old Jun 24, 2022 | 05:49 PM
BMWguy22's Avatar
+1
The only reason I had my clutch replaced on my 88 3 series, was due to a faulty throw out bearing.
Old Jun 24, 2022 | 09:49 PM
New Clutch.
Dam right.
The new Clutch feels great. Clutch pedal kicks in right away. Not like before half way up.
Car runs smoother and alot quieter. Just like I drove off the Honda Dealer parking lot in 2015.
Old Jul 24, 2022 | 04:05 AM
Zeltergiest's Avatar
What clutch and parts did you go with? Did you install it yourself?
Old Jul 24, 2022 | 07:48 AM
Clutch Install.
I had my local Honda Dealer install the clutch. It runs great now. Alot more pull from a stop.
Old Jul 24, 2022 | 06:21 PM
Glad to hear it runs great now. My fit has about 28k miles on it and the stock clutch is still super strong. I was just curious about what parts were used but if a Honda Dealer did the work it should be all OEM parts. Do you mind if I ask how much they charged you for parts and labor? You also mentioned the clutch engagement point is a lot better now. That's one thing I noticed about my fit, the friction point is really high up (a little over half way of total clutch movement) before it starts to grab, however once it does its a strong connection, no slipping. I've talked to various other fit owners and they claim it's nothing to worry about, it's set that way from the factory.
Old Jul 24, 2022 | 06:27 PM
While on the subject, another thing I noticed when shifting under hard acceleration is rev hang, have you experienced this in your fit? I've seen online it's caused by a clutch delay valve and a lot of people do a delete because it isn't needed and they find the rev hang annoying. I also find it annoying so it was something I was looking into doing.
Old Jul 24, 2022 | 06:34 PM
Cost.
Clutch, Pressure Plate, Flywheel. Along with Front Alignment, new Trans. Fluid. I had to buy the parts. All factory Honda. Total price was 4200 dollars. Not cheap. My Fit is running great.
Old Aug 18, 2022 | 02:49 AM
RD36's Avatar
Everytime I drive the GK I always feel like slapping on the EM civic CMC and improve the shift. I think the delay valve is detrimental and unnecessary. I have the part for the swap. Might do it one day.
The Proper Fit
Feb 9, 2026 12:04 PM
kgmcgrath
Jun 23, 2022 09:15 PM
RubyQQ1211
Jun 24, 2021 05:53 AM
radfit
May 11, 2012 11:54 PM
synmyo
Aug 29, 2010 08:06 AM
